Forum Index : Microcontroller and PC projects : Supported LCD's
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1134 |
Does anyone have a consolidated list of 'mites (all breeds) and the supported LCDs for each one? Also helpful would be an indication of MMBasic version, whether inbuilt or loadable driver? If not, any partial lists would be helpful as I have started to create my own list but thought to ask the 'shed' so I was not re-inventing the wheel. panky ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1131 |
matherp's H7 manual does have a bit of a MM family Summary near the beginning. May be of some help to you Brian ChopperP |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1151 |
Hi Panky, LCD Summary on Fruit of the Shed inspired by your similar post some time ago.Covers the LCDs and drivers available for each mite type. Regards, Gerry Edited 2020-05-11 11:47 by disco4now F4 H7FotSF4xGT |
@ Gerry We need to promote Fruit of the Shed a bit more ![]() ChopperP |
