Local Time 07:15 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Syntax changes in V5.05.04 you can code for now
Posted: 02:17pm 05 Jul 2020
There are/will be a small number of simple syntax changes in V5.05.04 that you can code for now to ensure programs are future proof going forward
in V5.05.04b3a
WS2812 renamed BITBANG WS2812 otherwise syntax the same
FFT replaced by MATH FFT otherwise syntax the same
TTS replaced by PLAY TTS otherwise syntax the same
FONT 4 replaced by a 224 character 10x16 font - use FONT 3 for a font of the same size and with the same characters as font 4
from V5.05.04b3b onwards
NUNCHUK replaced by WII NUNCHUK otherwise syntax the same. Note the NUNCHUK function is not affected. This will allow for a new, to-be-written, command WII CLASSIC and a new function CLASSIC()
You can allow for these changes easily using MM.INFO(VERSION) e.g.
if mm.info(version) < 5.0504 then
   TTS "Something to say"
else
   PLAY TTS "Somthing to say"
endif
In addition 2 commands in V5.05.03 that weren't included in the 5.05.03 user manual have been removed
BITMAP command  - removed
PLAY SPEECH command - removed
I don't anticipate any further changes that will affect how existing programs run other than bug fixes. Of course there is/will be new functionality in V5.05.04 that doesn't exist in V5.05.03 and if you use this it should be made clear in any programs you distribute
Posted: 02:46pm 05 Jul 2020
Just a nudge but is the (V5.05.04) CMM2 tokenizer happy with the TTS when missing PLAY before it?  E.g. does it just in effect convert it to PLAY TTS?
Edited 2020-07-06 00:47 by JohnS
Posted: 02:56pm 05 Jul 2020
  Quote  Just a nudge but is the (V5.05.04) CMM2 tokenizer happy with the TTS when missing PLAY before it?  E.g. does it just in effect convert it to PLAY TTS?
Only PLAY is tokenised. This is one of the beauties of an interpreter. On 5.05.04 the old version would give an error if executed but because it isn't there is no issue - and visa versa of course
Edited 2020-07-06 00:57 by matherp
