Local Time 04:42 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Error : Writing to port: The semaphore
Bizzie
Posted: 08:26am 25 Jul 2020
I am having great problems tracking down the above error. It is being generated very randomly by an MM-DOS program.
Can someone please tell me what the message means?
Here is the code, An HC-12 is connected to Com3 via a Freetronics USB- Serial adapter (JayCar).
While a MM170 is connected to the remote end via another HC-12. The MM170 is looking for a number of commands eg "Pressure" and then sending the value back.
Option explicit
Const ComPort = 3
Dim Buff$ As string
Dim Tmp As string
Dim CurrPress As integer = 0
Dim PrevPress As integer = -1
Dim CntON As integer = 0
Open "COM3: baud=9600" As ComPort
Do While Loc(ComPort)
   Tmp = Input$(20,ComPort)
   GetPress
   Pause 5000
   Buff = ""
Sub GetPress
   Local ThisStrVal As string
   Local PosPress As integer
   Print #3, "Pressure"
       buff$ = buff$ + Input$(200,ComPort)
   PosPress = Instr(UCase$(Buff),"PRESSURE")
   If PosPress Then
       ThisStrVal = Mid$(Buff,posPress+10)
       PrevPress = CurrPress
       CurrPress = Val(ThisStrVal)
       Print Timer;" Pressure = ";CurrPress,CntON
       If CurrPress > PrevPress + 200 And PrevPress > 0 Then
           CntON = CntON + 1
           Open "WhyPress.txt" For APPEND As #1
           If CntON Then
               Print #1,Time$;" ";Date$;" ";Timer;" ";CurrPress;" Pump ON ";CntON
               Print "PUMP ON "
           EndIf
           Close #1
       EndIf
   EndIf
End Sub
If I use TeraTerm instead of MM-DOS all seems fine.
Rob White
