Local Time 02:49 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Cmm2 time not saved when power removed
nad007007
Posted: 10:15am 28 Jul 2020
Hello
I have brought a new Cmm2 completed from https://www.rictech.nz/products/31/COLOUR-MAXIMITE-2 and time not saved when power removed with new battery installed.
Also when using Tera term when i paste a program i get random characters.
the first few lines are fine but if i copy a 6000 line of code its all messed up.
Hope someone can help.
Conrad
romba6
Posted: 11:08am 28 Jul 2020
Re the Teraterm issue you may need to introduce a
Transmit delay e.g 1ms/char
and 50 msec/line
These are in the Serial Port setup of Teraterm
nad007007
Posted: 11:27am 28 Jul 2020
Hi romba6
Thank you for your reply.
I have also been playing with Transmit delay e.g 1ms/char
and 50 msec/line for a few days and have tried your suggestion and i still get some errors with missing or messed characters.
Conrad
Posted: 12:28pm 28 Jul 2020
Use XMODEM rather than AUTOSAVE
nad007007
Posted: 01:05pm 28 Jul 2020
Hi matherp
Thanks for your reply.
I had thought of using xmodem and had tried xmodem to send .bmp files. If using Tera term to paste programs is broken with cmm2 then i will use xmodem.
Conrad
Posted: 01:32pm 28 Jul 2020
Hi Conrad,
I have only Loaded programs by writing to the SD card in my pc.
But as for the battery problem can you measure the voltage across the battery holder with the battery inserted?
Maybe the battery holder is faulty or there is a short somewhere that flattens the battery..
Does the battery holder look like it’s soldered on both pads?
Is the battery holder mounted the same orientation as the silkscreen on the pcb?
It is not normal, I have found the time keeps relatively good time when powered off (in the vicinity of 5-10seconds per day) without any RTC trimming.. It is one of the things I test on all of the cmm2 I build.  (Not 24hrs but several hours)
nad007007
Posted: 01:46pm 29 Jul 2020
Hi bigmik
Thanks for your reply. I am getting 3.08 volts across the battery. Not sure what happened but when i power the cmm2 off for 10 seconds the time and date is now saving.
Conrad
