Local Time 02:49 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with ILI9341 'keypad'
mikedownunder
Posted: 02:12am 29 Jul 2020
Hi Guys
Running Micromite V5.05.03
Countdown Timer.zip
Been using this software for a while and recently updated my hardware.
To rule this out I connected my display to a V2 backpack.
As you can probably see I originally got this from one of GeoofG's projects.
For some strange reason I am now getting an error whenever I change a number and press the "ENT" key. Everything else works as expected.
If I run it in MMEDIT V4.0 everything is OK, however as soon as the ENT key is pressed the following message appears in Micromite_5.05.01 Chat.
[311] If Btn = 16 And S <> "" Then VAR = Val(S)
Error : Unknown command
Any ideas out there?
Mike
Turbo46
Posted: 02:40am 29 Jul 2020
VAR is a command, you cannot use it as a variable name. I'm surprised that you can get away with declaring it.
Bill
mikedownunder
Posted: 05:27am 31 Jul 2020
I originally constructed this from one of Geoff's projects a couple of years back and all worked well until I made a small change to my hardware. Whilst doing this I also upgraded the firmware in the micro to the latest and I beleive that this is where the problem has arisen.
The error comes from the LCD keypad routine where it saves the 'ENT' key(16) to VAR which obviously is no longer allowed.
Once I changed all variances to Var3 and reinstalled, everything works OK again.
Incidentally this is exactly the same with the Parking Assist software.
Thanks Bill for pointing me in the right direction.
Mike
Turbo46
Posted: 06:45am 31 Jul 2020
You're welcome Mike and thanks for responding. I think there are a few of those gotchas from old programs. I just checked the code on Geoff's site for the parking assistant and it's still there.
Bill
