Local Time 01:54 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 - Draw a Pixel
mxck
Posted: 11:13am 03 Aug 2020
Hi all,
I was reading through the manual and noticed the PIXEL command allows either a single value or arrays to be passed into it to draw pixels. Would it be fair to assume using the array version of it is faster than calling the command separately every time?
When trying to use it I wasn't quite sure how it would work. Here's a tiny program that I expected to work. Your help is much appreciated!
Mx.
mode 3, 16
dim integer x(1) = (0, 10)
dim integer y(1) = (20, 30)
color rgb(green)
pixel x, y
do
loop
Posted: 11:19am 03 Aug 2020
Like all commands when passing arrays you need brackets on the variable
mode 3, 16
color rgb(green)
pixel x(), y()
do
loop
  Quote  I was reading through the manual and noticed the PIXEL command allows either a single value or arrays to be passed into it to draw pixels. Would it be fair to assume using the array version of it is faster than calling the command separately every time?
Most drawing commands allow arrays and it can make a HUGE difference to performance
Edited 2020-08-03 21:19 by matherp
mxck
Posted: 09:16pm 03 Aug 2020
Great, thanks for the tip!
