Local Time 00:56 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SC Demo prog failure
BobDevries
Posted: 08:14am 07 Aug 2020
Hi all,
I haven't seen any comments/posts on the CMM2 article in Silicon Chip (pp88). I typed it in and checked it over and over but I still cannot get it to push a ball around the screen; all I get is a same-size "bar"bounce off the screen extremities. I tried a few mods, without success.
Did anyone get this working?
Regards, Bob Devries
Bob Devries
Dalby, QLD, Australia
Posted: 09:53am 07 Aug 2020
Maybe zip up the code and post it for those who don't have SC but may see the problem.
Posted: 12:44pm 07 Aug 2020
It worked for me!
Posted: 03:14pm 07 Aug 2020
I guess it's something like a typo.
Posted: 04:00pm 07 Aug 2020
This is the program, perhaps you can copy and paste it:
BOX 0, 0, 800, 600, 1, RGB(yellow), RGB(black)
x = 400
y = 300
dx = 1
dy = 1
DO
 CIRCLE x, y, 30, 2, ,0, RGB(red)
 x = x + dx
 IF x = 31 OR x = 767 THEN dx = dx * -1
 y = y + dy
 IF y = 31 OR y = 567 THEN dy = dy * -1
 PAUSE 2
LOOP
For people who don't have access to the SC article; this program will cause a red ball to zoom around the screen bouncing off the walls.  It is not particularly complex, nor useful, but it does provide a simple demo of graphics on the CMM2.
mclout999
Posted: 05:21pm 07 Aug 2020
  Geoffg said  This is the program, perhaps you can copy and paste it:
x = 400
y = 300
dx = 1
dy = 1
DO
 x = x + dx
 y = y + dy
 PAUSE 2
LOOP
This little demo just showed I have a issue with the video output of my CMM2.  The demo draws the outside boarder on the screen and on my system it has 1 pixel cut off on the right side.  I have changed the aspect ration of the screen to 1 to 1 and it is just not able to display the last colum of pixels. I edited the demo with everything 1 pixle less and it works but This is not cool. I have gone back to several other demos and it is differently as issue with my system. It is like the viewing screen onto the output is 1 pixle to the left.
Does anyone know what could be causeing this.  I have fully assembled system form micromite.org. I am attached to a VGA monitor.  EDIT:  I just attached it to 2 other displays and one had just a half a pixel cut off and the second one had 1 and 1/2 pixels cut off. and they are ghosting an inverted copy of the 2 pixel columns just off-screen It is like the first 2 pixel columns for the left side are being displayed on the right a few pixels past the screen area.
Edited 2020-08-08 03:34 by mclout999
berighteous
Posted: 05:29pm 07 Aug 2020
Have you tried an auto calibrate on your monitor?  My display was wonky at first but I pulled up the on screen display for my monitor and hit the auto calibrate button and it fixed it.
Posted: 05:30pm 07 Aug 2020
Most monitors have a "auto adjust" button or menu item which syncs the monitor to the source. Try and find it and use it. Normally solves this sort of issue
mclout999
Posted: 05:55pm 07 Aug 2020
I have not used auto ajust in a long time and yes that is all it was.  The problem with my monitor is that it is only accessible from on undocumented long-press on a button used for backing out of menus (ASUS) had to find a PDF of the damn manual to find it. NOT very intuitive and thanks all for prompt help as always.
