Local Time 22:24 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Hey Glen, the forum software is not resetting the message read flag.
Paul_L
Posted: 02:47am 14 Aug 2020
Hey Glenn ...
for the first 6 1/2 pages of threads, back to July 26, the new message flag is not re-setting. I logged out then logged in again ... no change.
Paul in NY
Posted: 03:04am 14 Aug 2020
You sent me a message about this, I know about it, didn't need its own topic.
The forum has lots of little bugs, working on them as time allows.
Posted: 03:07am 14 Aug 2020
Glenn, all,
I have noticed this too, but it seems to correct itself after a few hours..
The biggest problem is I dont get notifications of a PM .. I get message notifications but not PM.
Paul_L
Posted: 04:57pm 14 Aug 2020
  Gizmo said  You sent me a message about this, I know about it, didn't need its own topic.
Speaking of which, that's another bug. I couldn't send you a message, or at least it didn't seem to work.
Take it easy ... you'll get them fixed eventually.
Paul in NY
Paul_L
Posted: 05:33pm 14 Aug 2020
HEY ... IT'S WORKING!!!
Paul in NY
Paul_L
Posted: 09:24pm 14 Aug 2020
Whoops, it stopped working totally. Now there are no new post indications at all.
Paul in NY
CircuitGizmos
Posted: 11:05pm 14 Aug 2020
Always hit or miss for me.
Posted: 12:23am 16 Aug 2020
To make this work the code needs to detect when the user last left the web site, so it can display any new posts with a date stamp after that date/time
Reliably detecting when a person leaves a web site is tricky, it depends if the user closes the browser, which means the session is killed cleanly, or if they just navigate to another web site, which means the session will fizzle out later. And some browsers ( Safari ) are just plain pricks and wont tell you anything. As soon as you get the code to work, a OS update on the client breaks the code. Browsers dont like web sites asking to many questions.
So the code did work fine a few weeks ago, but some update has broken it, and I'll get to it in the next few days. For now, just use the Active Topics page.
Please post messages about forum bugs in Site News or as a message to me ( I do read them ), dont clutter other topics.
Posted: 12:51am 16 Aug 2020
Hi Glen,
I must make it hard for you, I access TBS using an iPad, PC win10 Firefox, and my iPhone..
Depends on where I am and what I am doing.
It’s no big deal for me, however I would like the notification of a PM to be emailed to me I might miss the number next to the message in the top of the main menu screen.
Paul_L
Posted: 02:39am 17 Aug 2020
Hi Glen,
I logged in and read posts about 8 hours ago.
I logged in again a half hour ago and only newer modified threads were flagged as they should be.
I read the marked threads, went to another website, closed the browser, restarted the browser and went to TBF again. This time the thread read flags were not reset.
When, exactly, does the software reset this flag?
Paul in NY
Paul_L
Posted: 02:42am 17 Aug 2020
Hi Glen,
I just posted the above and when the forum list reappeared the read flags were reset which is as it should be.
Hmmmmmmmmm....
Paul in NY
Posted: 12:25pm 17 Aug 2020
This is how it works. This is the simple way of doing it.
The codes uses cookies and sessions. Sessions time out after you leave the web site AND/OR close the browser, plus a few minutes. If you leave the browser open, even to visit another site, or go make a coffee, and come back, the session is still active.
Cookies last longer, 1 year in this case, the forum uses that cookie if you tick the box to remained logged in.
When you visit the site, the code checks to see if the session is still active. If it isn't, it looks for the cookie. If it finds the cookie, it looks up your details in the database including a field called "LastVisit", and stores this in a variable, and sets up the session to keep track of you. It then puts the current datetime into the database, a new "LastVisit".  So now you are logged in, but the datetime of your last log in, the LastVisit, is stored in a variable ( and a fresh one is in the database for the next time you visit ).
The codes compares this old LastVisit datetime to the datetime of the posts in the forum. If the post was saved AFTER your LastVisit, it flags the post as new.
So, if the session doesn't expire, the code has no reason to look up your last LastVisit. Remember, sessions can hang around longer than you like. If you close the browser or shutdown the computer, and go make a sandwich, it will probably clear, eventually.
This system works well enough. It flags posts saved after your last LastVisit datetime.
A better system would store the date and time of every post you read, ( eg, you opened the only/last page of a thread ), and save all that data ( post ID and datetime ), and compare that to the current time, to display the unread flag. This would mean every time you visit the page that lists the posts, the code would need to get the last datetime of every post on the page, and look up your data for a matching post ID, and check its date. This means more CPU time and a bigger database.
But I'm not going to do this.
