Local Time 22:23 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 5.0.05b11 kills Soccer and Rotate
Posted: 02:35am 20 Aug 2020
GDay All, Peter,
I have just updated from 5.0505b5 to b11 and the rotating SOCCER ball and the Rotating polygon coloured ball now fail with the error
[14] Error: phi is not declared
We all know I am not the best programmer but I had a look at the code and phi is declared as a FLOAT..
What do I need to look at to fix this to allow them to run on the later version?
I have attached the 2 files here
Soccer and Rotate.zip
Kind Regards
Edited 2020-08-20 12:36 by bigmik
yock1960
Posted: 02:47am 20 Aug 2020
You need to capitalize all the references to phi in the data statements.
Steve
Posted: 06:47am 20 Aug 2020
This will be fixed in b12 thanks to a clever idea from Geoff
