Local Time 21:40 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Autorun.bas?
yock1960
Posted: 08:07pm 23 Aug 2020
I haven't seen anything that suggests this is possible, could it be? Run this program if it exists or boot as normal if not.
Steve
realmnm
Posted: 08:19pm 23 Aug 2020
From the manual:
OPTIONAUTORUNOFF|ON
Instruct MMBasic to automatically run the program stored in program memory when it starts up or is restarted by the WATCHDOG command. This is turned off by the NEW command but other commands that might change program memory (EDIT, etc) do not change this setting.
Entering the break key (default CTRL-C) at the console will interrupt the running program and return to the command prompt.
This signature intentionally left blank.
yock1960
Posted: 08:27pm 23 Aug 2020
Ah. Thanks!
