Local Time 21:38 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Maths Issue (MATH Q_ROTATE)
x4nd
Posted: 06:37pm 24 Aug 2020
Hi All,
I guess this is a question for Peter Mather, given he's the "Maths Wiz"?
I have been exploring the rotating ball Icosahedron demo program.  Making it do different things, run faster, etc.  I decided to try to port it to the new maths functions, "MATH Q_ROTATE" being the main one for the main loop of the rotating ball.  It looks like it should be a drop-in replacement for the existing "rotate_vector" function, but I'm getting very odd results which then made me think that I didn't understand the quaternions at all.
So, does this function work properly?  If you do take that program and exchange the interpreted function for the built-in version does it work?  Been scratching my head about this for quite a few hours.  I don't seem to be able to get results that mean anything sensible.
Anyhow, I'm loving the CMM2 so far - it's beyond my expectations and really fun to play with.
-Stuart
If only there were more hours in the day..
Posted: 06:41pm 24 Aug 2020
The order of the parameters in the q array are different as they were a bit illogical in the Basic version. If you get these right then it will work. I did update the rotating ball to the MATH versions and got about a 25% speed improvement. Much of the time is taken in the plotting. Unfortunately I then overwrote the updated version so I can't post it.
x4nd
Posted: 06:57pm 24 Aug 2020
No problem.  I got the interpreted version up to 30fps and would like more speed!  I'll have another look at the ordering of the quaternions.
I assume it should be w-x-y-z-mag.  I think the interpreted version is mag-w-x-y-z?
Anyhoo - more playing.
Thanks for your time.
