Local Time 19:34 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: BBEdit Language Module
djwildstar
Posted: 05:38pm 02 Sep 2020
I don't know how many (if any) CMM2 folks are Mac users, but here is a BBEdit codeless language module for MMBasic 5.05.05.  I've implemented basic syntax coloring (comments, strings, keywords, and predefined symbols), code completion, subroutine and function detection (so that BBEdit builds a list of functions, and can fold function bodies), along with  support for commenting-out lines and blocks of code.  I've bound the definition to .BAS and .INC files.
To install, open BBEdit Preferences, click on Languages and then the "Language Modules" link.  This will open the BBEdit application support folder in a Finder window.  Drag the CMM2 BASIC.plist file into the Language Modules folder, then quit and re-start BBEdit.
Let me know if you see any oddities or bugs.  One known oddity is that if a symbol is both a keyword and a function, I had to decide if it went on the pre-defined symbol list or the keyword list - it can't be in both places.  In some cases, this decision was somewhat arbitrary.  Also, I omitted some commonly-used parameters (such as ON, OFF, ENABLE, DISABLE, I, B,  etc.) to avoid confusion.
CMM2 BASIC.plist.zip
jean-yves
Posted: 05:44pm 05 Sep 2020
Nice work.
If you send the download link to BareBones they will add it to their list: http://www.barebones.com/support/bbedit/plugin_library.html
I've sent them a couple myself.
