Local Time 19:33 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Soft Reset, maybe?
Pilot352
Posted: 04:26pm 05 Sep 2020
Would it be possible to implement a CTRL/ALT DEL soft reset of the Maximite to reset the mmbasic to some point after a lockup? Cycling power is a pain and the reset button on the single board version requires a disassembly of the case to use. Just an thought/idea/request to consider.
RetroJoe
Posted: 05:21pm 05 Sep 2020
What makes cycling the power a pain? The CMM2 reboots in a few seconds.
Do you have a power switch installed, or do you need to yank and reinsert the USB power cord (which is indeed a pain...)?
Enjoy Every Sandwich / Joe P.
Posted: 05:27pm 05 Sep 2020
The idea is good but doesn't work. If the CPU has crashed it is not going to be processing the keyboard or serial port so wouldn't see the sequence
Pilot352
Posted: 05:29pm 05 Sep 2020
It means getting my fat butt off the couch. It's not a time thing, it would just be better to press a few keys. If a simple software change can add this feature why not? It also reduces the wear on the electronics (not that this is a big issue now).
Why the resistance to it if it can be done easily?
Pilot352
Posted: 05:32pm 05 Sep 2020
matherp, thanks for the consideration. I thought the keyboard routines were part of the interrupt structure. I see your point.
