Local Time 18:47 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Searching for a Terminal PGM for MM2 LCD Backpack
Canada_Cold
Posted: 11:27am 10 Sep 2020
Is there an option to see all of the results from a search?  The Search displays 50 only.
What I'm looking for is if someone has written a "terminal program" to run on a MM2 LCD Backpack?  I would like to use a MM2 LCD Backpack to display ASCII messages something like Tera Term does without having to use a PC.  BTW, I don't need to send from the Terminal, simply RX on a COMM port only.
Thanks, Don
Posted: 11:32am 10 Sep 2020
  Canada_Cold said  Is there an option to see all of the results from a search?  The Search displays 50 only.
You can always use a browser search: "searchterms site:www.thebackshed.com"
Canada_Cold
Posted: 02:57pm 10 Sep 2020
Great, that helps with the search.  Thanks
datawiz
Posted: 04:13pm 10 Sep 2020
  Canada_Cold said  Hi,
Thanks, Don
Don,
I wrote a wifi library for the CMM2 (Thread Here)
Code Here
In the zip file for the code are a few example programs, including "terminal.bas", which is a very simple terminal program that you may be able to modify for your purposes. The ESP8266 is connected via serial port on the CMM2, so it should work just like any serial connection. You will probably need to comment out/remove any specific wifi library calls, and define the COM port and baud rate, but the core of it should work.
If you need any help modifying it, feel free to reach out.
Thanks,
Rich/dw
Canada_Cold
Posted: 11:16pm 11 Sep 2020
Hi Rich,  thanks for posting this, I have it now.  Had a quick look at it, very complex, will take me some time to understand it.
Thanks, Don
datawiz
Posted: 03:09pm 12 Sep 2020
  Canada_Cold said  Hi Rich,  thanks for posting this, I have it now.  Had a quick look at it, very complex, will take me some time to understand it.
Thanks, Don
Don-- I've boiled it down to the 'basics' for you. :)
Rich/dw
dim COM_PORT$ = "COM2" ' replace with COM1 or COM2
dim COM_SPEED$ = "115200" ' replace with baud rate
dim CHAR_OUT$
dim CHARS_IN$
cls
open COM_PORT$+":"+COM_SPEED$+","+"256"+",get_serial_input" as 5
print "Terminal running, press ESC to exit."
do
 CHAR_OUT$ = INKEY$
 if CHAR_OUT$ <> "" then
   if CHAR_OUT$ = chr$(27) then exit
   print #5, CHAR_OUT$;
 end if
loop
close #5
end
sub get_serial_input
 CHARS_IN$ = input$(LOC(#5),#5)
 print CHARS_IN$;
end sub
