Local Time 15:27 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Passing arrays to a SUB / Function
elk1984
Posted: 04:52pm 27 Sep 2020
Another noob question, is it possible to pass an array of values into a SUB without first assigning them to a variable?  Something like:
MyCodeThatNeedsAnArray((1,2,3))
END
SUB MyCodeThatNeedsAnArray(paramArray() as Integer)
END SUB
As another noob question - is it possible to get the upper bounds of an array (I'm not trying to restart that Base 0 vs Base 1 discussion  )
elk1984
Posted: 05:10pm 27 Sep 2020
Try the BOUND function
elk1984
Posted: 06:16pm 27 Sep 2020
  matherp said  Try the BOUND function
Thanks - right under my nose
William Leue
Posted: 06:34pm 27 Sep 2020
Hmm, the docs don't mention a BOUND function and MMBasic on my CMM2 does not either. Do you mean some special way of using a function? Or is this only available in a firmware version higher than 5.05.04?
-Bill
twofingers
Posted: 07:14pm 27 Sep 2020
  William Leue said  Hmm, the docs don't mention a BOUND function and MMBasic on my CMM2 does not either. Do you mean some special way of using a function? Or is this only available in a firmware version higher than 5.05.04?
-Bill
S. p93 (V5.05.04)
The lone and ...
