Local Time 15:27 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Sprite vs Blit
William33
Posted: 09:37am 29 Sep 2020
Hi, maybe someone can point out what am I doing wrong here ...
' sprite vs blit
' just a test
cls
page write 2
cls
load png "knight.png",0,0,1
load bmp "grass.bmp",32,0
sprite loadpng 1, "knight.png"
page write 1
cls
for x= 0 to mm.hres step 32
 for y=0 to mm.vres step 32
   blit 32,0,x,y,32,32,2
 next
next
blit 0,0,200,200,32,32,2,&b100
sprite show 1,100,100,1,0
page copy 1 to 0
do
loop until inkey$<>""
The above code works fine - result is as follows:
Apart from that the RGB (10,10,10) - darker pixels of the image - is also blitted transparent.
Anyway, if I am commenting the BLIT line out, the sprite isn't transparent anymore:
So, what am i doing wrong here? By the way, it doesn't matter which mode I use.
Posted: 10:10am 29 Sep 2020
Can't really tell anything without the png file. The obvious answer is that it has a non-transparent black background.
William33
Posted: 11:30am 29 Sep 2020
Okay, here's the png file attached to this message. I zipped it because in the preview it really seemed to have a black background ...
knight.png.zip
William33
Posted: 01:02pm 29 Sep 2020
Well, if I don't do a page copy, i.e. I add a "page write 0" then the sprite is displayed correctly. So isn't it possible to show a (transparent) sprite on page 1 and copy the page to page 0?
Edited 2020-09-29 23:03 by William33
Posted: 01:17pm 29 Sep 2020
It is a firmware bug that a software bug in your code found.
Try this:
for x= 0 to mm.hres-1 step 32
for y=0 to mm.vres-1 step 32
  blit 32,0,x,y,32,32,2,0
next
next
In your original code the last blit was off-screen. The firmware tests for this and returns without doing anything. However, at this point it has overridden the read page address and didn't restore it. Will be fixed in V5.05.06b15 when posted.
Edited 2020-09-29 23:23 by matherp
William33
Posted: 01:30pm 29 Sep 2020
Ok, thanks, this does the trick. And of course thanks for the upcoming fix.
Edited 2020-09-29 23:32 by William33
