Local Time 14:53 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 ERROR: SYSTEM FAULT - CHECK CODE
Chopperp
Posted: 01:04pm 04 Oct 2020
Up till recently, if I got an error, the line number etc would display & also the line number would be indicated when F4 on the console was pressed to bring up the program.
Now, on an error, I get a blank screen with the message
CMM2 ERROR: SYSTEM FAULT - CHECK CODE.
Initially thought that there was no obvious indication as to where or what the fault was. Printing MM.ERRRNO just said 0
I ended up recording the screen & eventually found that the original message referring to fault in the line number briefly flashed up & then the screen went blank with the ERROR: etc message showing.
First time it happened was with an out of bounds array & the latest one was an inadvertent space in a variable.
Running b14
Any ideas?
May or may not be related, but I'm getting an XMODEM Syntax error if I try to Load & Run current code from within MMEdit.
I can transfer the file to the CMM2 with MM File OK although the CMM2's files aren't being listed.
I may just need to reload MMEdit.
Brian
ChopperP
Posted: 01:16pm 04 Oct 2020
Please update to b17. These are betas and some were more beta than others
Chopperp
Posted: 01:19pm 04 Oct 2020
OK. Will advise tomorrow
ChopperP
Chopperp
Double post??
Edited 2020-10-04 23:27 by Chopperp
ChopperP
Chopperp
Posted: 01:41pm 04 Oct 2020
OK, b17 fixed the error messages.
XMODEM still not OK. May be one for Jim.
ChopperP
CircuitGizmos
Posted: 05:36pm 04 Oct 2020
Make sure that MMEdit is set to be talking to a CMM2.
Chopperp
Posted: 10:04pm 04 Oct 2020
Dah,
Thanks CG, that fixed it. Works when set to CMM2.
Forgot about that setting. Must have inadvertently changed it.
CMM2 going great BTW
Edited 2020-10-05 08:04 by Chopperp
ChopperP
CircuitGizmos
Posted: 03:01pm 05 Oct 2020
