Local Time 14:11 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with 5D integer array
William Leue
Posted: 08:07pm 10 Oct 2020
I am getting "Error: Dimensions" when I try to use this
option default integer
option base 1
dim Stuff(12, 4, 2, 5, 3)
This is only 1440 integer values, surely not too large. According to the docs, MMBasic is supposed to support arrays with 5 dimensions.
The firmware version is 5.05.05
Any clues?
-Bill
twofingers
Posted: 10:16pm 10 Oct 2020
Hi Bill,
IMHO you found your first BUG! Congratulation!
With "Option Base 1" I get the mysterious error even for DIM Stuff(1) - after I executed your code -, but not always reproducible. Strange!
I get an error for this:_
option base 1
dim integer test(1)
Without this both options:
option base 1
I can execute
DIM stuff(1200,4,2,5)
without an issue, but DIM stuff(12,4,2,5,0) results in an (Dimension) error.
I have never encountered problems related to DIM in the past.
MMBasic CMM2_Beta - V5.05.06RC2
Michael
Edited 2020-10-11 08:31 by twofingers
The lone and ...
William Leue
Posted: 10:49pm 10 Oct 2020
Ok well I'm glad it's not just some idiot mistake of mine. I'll be interested in hearing Peter's take on this.
-Bill
mkopack73
Posted: 01:56am 11 Oct 2020
  twofingers said  Hi Bill,
option base 1
dim integer test(1)
option base 1
I can execute
Michael
Ok, well, just a shot in the dark but:
If you ARE using OPTION BASE 1, then a dimension of value of 1 isn't actually a dimension - it's a single cell.
Without OPTION BASE 1 (ie BASE 0), then setting the value to 0 is again setting it to a single value which isn't an array then...
However, that doesn't explain why the OP's code didn't work.
Posted: 07:58am 11 Oct 2020
  Quote   DIM stuff(12,4,2,5,0) results in an (Dimension) error.
This looks like a day-1 MMBasic bug. Will liaise with Geoff and fix in next release
  Quote    If you ARE using OPTION BASE 1, then a dimension of value of 1 isn't actually a dimension - it's a single cell.
This correctly gives an error
