Local Time 14:11 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Random Freezes on the CMM2
TweakerRay
Posted: 10:30pm 10 Oct 2020
Hi ! I don't know if its because of the new firmware or anything else... but I also tried a new powersupply which must give enough power to the machine...
so It happens very randomly if I edit a file and run a programm... sometimes the programm starts and then just freezes...
I turn off and on the machine and then it works... but it is really anoying since I don't know what triggers this... I think it wasn't like that before I made the updates of the firmware or maybe I am figuring it out because I do more on the cmm2 now...
any advice what i could do ?
Thanks again for your help !
Cheers TweakerRay
http://tweakerray.bandcamp.com
William Leue
Posted: 10:53pm 10 Oct 2020
It happens to me too. I recently updated from 5.05.03 to 5.05.05 but it does not seem to have fixed the problem.
However, I have found that most, but not all of the freezes are caused by a mistake of mine.
If your MMBasic program opens a file but fails to close it, the hang happens a lot. I suspect it means that the firmware is hung up waiting for an I/O completion that never happens.
If I am careful to always include a 'close' statement in all the cases where the program terminates, the problem is largely avoided. Of course, if the program crashes on an error or gets the Ctrl-C two-finger salute, it can still happen.
-Bill
mclout999
Posted: 11:51pm 10 Oct 2020
In the past several including me have found that the power source I was using was the issue.  I was on a powered USB hub and that was the cause.  On a good charger I have had very few issues and only a few crashes from my own tinkering.  Try a diffent power souce.
Edited 2020-10-11 15:45 by mclout999
TweakerRay
Posted: 11:55am 11 Oct 2020
  mclout999 said  In the past several including me have found that the power source I was using was the issue.  I was on a powered USB hub and that was the cause.  On a good charger I have had very few issues and only a few crashes from my own tinkering.  Try a diffent power souce.
I am using now a different powersupply which has much more power...
So the CMM2 should get enough power...
it was not the problem before with the old powersupply
so I daubt it is a powersupply error... because I am experiencing the same with other powersupply... but it was worth a try ;-)
I was just checking if other people may have the same issue...
Cheers TweakerRay
