Local Time 09:38 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Sprite vs. background question
epsilon
Posted: 09:28am 13 Oct 2020
Hi all,
I don't fully understand how on CMM2 sprites work relative to the background.
I'm in 8-bit mode. I have a sprite the size of a character. Here is the code fragment that confuses me:
TEXT 0,0, "A"   '1. Shows letter A in upper left corner
DO WHILE INKEY$="":LOOP:DO WHILE INKEY$<>"":LOOP 'Wait for key press
SPRITE SHOW 2, 0, 0, 2  '2. Shows sprite with letter A underneath.
TEXT 0,0, "V" '3. Show letter V in upper left corner
SPRITE SHOW 2, 0, 0, 2 '4. Show sprite with letter A underneath (why not V?)
Step 3. The letter V overwrites the sprite. This shows that sprites don't live in a separate plane before or behind the background. They behave more like stickers that get pasted on the background. OK.
Step 4 however I don't understand. I'm redisplaying the sprite here so I was expecting to see the sprite with the letter V underneath. Instead I see the letter A underneath. Where did that come from?
Here is the full code:
OPTION BASE 0
MODE 1, 8
FONT 1, 1
DIM CRSR_INS_SPRITE%(MM.INFO(FONTWIDTH)*MM.INFO(FONTHEIGHT)-1)
CRSR_INS_SPRITE_DATA:
DATA RGB(WHITE), RGB(WHITE), 0, 0, 0, 0 ,0 ,0
SUB initInsSprite
 LOCAL ii%
 RESTORE CRSR_INS_SPRITE_DATA
 FOR ii%=0 TO MM.INFO(FONTWIDTH)*MM.INFO(FONTHEIGHT)-1
     READ CRSR_INS_SPRITE%(ii%)
 NEXT ii%
END SUB
initInsSprite
SPRITE LOADARRAY 2, MM.INFO(FONTWIDTH), MM.INFO(FONTHEIGHT), CRSR_INS_SPRITE%()
TEXT 0,0, "A"
TEXT 0,0, "V"
Thanks for any help,
Ruben/Epsilon
Epsilon CMM2 projects
Posted: 09:45am 13 Oct 2020
Sprites are implemented in S/W. When you first display a sprite it saves the background where it will be displayed and then overwrites it. When you move a sprite it restores the stored background in the old position, stores the background in the new position and then writes out the sprite.
If you need to write to the screen with non-sprite commands you must hide any sprites that may be overwritten first and then restore them after the non-sprite write.
An alternative is to write the sprites to a cleared to black page and then blit that page with transparency to the page on which you are using non-sprite writes.
Another alternative is to use 12-bit mode. Have the sprites on page 1 and everything else on page 0
Edited 2020-10-13 19:47 by matherp
epsilon
Posted: 10:20am 13 Oct 2020
Thank you for the quick response!
So this works fine:
TEXT 0,0, "A"
SPRITE HIDE 2 'Hide sprite because it will be overwritten.
TEXT 0,0, "V"
SPRITE SHOW 2, 0, 0, 2 'Redisplay sprite
Got it. So sprites don't automatically live on a separate 'plane', but you can still make it so. Cool!
epsilon
Posted: 07:59am 18 Nov 2020
I ran into a subtle issue with BLIT which manifests itself as an 'incorrect sprite background' issue, which started this thread.
Here is a code snippet that triggers the issue:
SPRITE LOADARRAY 2, 8, 12, CRSR_INS_SPRITE%()
DIM s0$ = "'--> Key Codes. Press Alt-K in the editor to see the keycode corresponding to a keypress. Combos with Ctrl, Shift and Alt are supported.  "
DIM s1$ = "'CONST FG_COLOR% = RGB(230, 230, 230)"
PAGE WRITE 4
CLS
TEXT 8, 12, MID$(s0$, 1, 98)
PAGE WRITE 0
CLS
SPRITE SHOW 2, 98*8, 12, 1, 0
SPRITE HIDE 2
TEXT 8, 12, MID$(s0$, 40, 98)
BLIT 8, 24, 8, 24, 0, 12, 4
So, in a nutshell:
1. I print a line of text and overlay a cursor shaped sprite.
2. I hide the sprite.
3. I modify the line of text.
4. I do a blit to a different part of the screen.
5. I redisplay the cursor shaped sprite.
The redisplayed sprite in step 5 now has an incorrect background. It looks as if I forgot to hide the sprite in step 2.
The issue is triggered by the funny BLIT in step 4. This BLIT has a width of 0.
You might just say "don't do that" and move on. My workaround is of course to protect the BLIT with an 'if width > 0...' (in my actual code, the BLIT parameters are the result of a computation obviously). However, I have two issues with this:
1. I now have to 'special case' an otherwise linear sequence of code. But more importantly:
2. BLIT doesn't flag a width of 0 as invalid. The BLIT proceeds as expected. It's only later, in a different part of the graphics subsystem (sprites) that an issue appears, which makes it very hard to track down the problem.
I have attached the complete test program.
Cheers,
Ruben/Epsilon.
xdbg.zip
Posted: 10:51am 18 Nov 2020
What version? - the code suggests this is fixed in RC21
epsilon
Posted: 11:40am 18 Nov 2020
This is still 5.05.05.
I haven't been brave enough to jump on the early adapter beta FW bandwagon.
The problem is that the program I'm writing and debugging is itself in alpha/beta stage and I'm just not looking forward to testing and debugging my alpha SW on beta FW.
Great to hear that this issue will be fixed in the next FW release however!
RetroJoe
Posted: 02:45pm 18 Nov 2020
Ruben,
Just curious - why the DO:INKEY:LOOP twice? Shouldn’t once be enough?
FYI, I went the other way i.e. towards the bleeding edge. Now, I think the springy things on my programming jumper block are wearing out from the daily firmware updates!
BTW, I distinctly remember (and it’s here on TBS somewhere...) Peter saying the CMM2 FW was feature complete, and no updates other than for bug fixes ;)
Cheers, and keep up the great work!
Enjoy Every Sandwich / Joe P.
twofingers
Posted: 02:58pm 18 Nov 2020
  RetroJoe said  ...Just curious - why the DO:INKEY:LOOP twice? Shouldn’t once be enough?
It is not the same twice!
The first loop stops as long as no key is pressed.
The second loop stops while a key is pressed.
Michael
Edited 2020-11-19 01:16 by twofingers
The lone and ...
jirsoft
Posted: 05:26pm 18 Nov 2020
I'm using it same way to prohibit "stuck" keys (but anyways it sometimes doesn't help...).
Jiri
epsilon
Posted: 05:40pm 18 Nov 2020
Exactly. The idea is to require a key press and a key release before moving on to the next statement.
For a very sensitive function like KEYDOWN additional debouncing might be needed. INKEY$ isn't that sensitive however so the above combo should be good enough, for a quick test program at least.
RetroJoe
Posted: 07:16pm 18 Nov 2020
Thanks - I missed the debouncing logic. Very nice!
RetroJoe
Posted: 07:18pm 18 Nov 2020
