Forum Index : Microcontroller and PC projects : Has anyone got
I'm after some older versions of Picromite I'm trying to find a version that BLIT and longstring works I'm looking for 2018-11-16_222927_mmbasicSTRETCH.zip 2018-09-27_222719_mmbasicSTRETCH.zip 2nd version with fixes or any versions after 5.4.20 where both Blit and Longstring works I'm using Stretch and have no interest in updating it to Buster or anything I "think" these are the only versions between 5.4.20 where Longstring was added and 5.05.01 where I know Blit does not work The versions listed on the forum are not available to dowload anymore |
| mclout999 Guru Joined: 05/07/2020 Location: United StatesPosts: 514 |
I was thinking of using one of my PIs but never did. I found these them all over the forum hope they help. I ziped what I had up. those 2 are in there. RASPI.zip They call me Shai-Hulud (The maker) |
Thanks not sure if they are any of the ones I'm after but I'll definitely check them out and let you knowThe pi works brilliantly with MM it's a shame it's been retired |
Thanks to both Lizby and mclout999 for their help with the older versions but unfortunately it didn't work. Peter if you'r watching this is there any easy way for me to modify version 5/4/16 to make longstring work? 5.4.16 both blit and longstring works but 5.4.21 upwords longstring works but blit doesn't I've tried every version I can find from 5.4.21 upwards |
| led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 210 |
I have most versions including: 2018-09-23_214847_5.4.21stretch 2018-09-24_232642_mmbasicstretch 2018-09-26_032429_mmbasicstretch 2018-09-27_222719_mmbasicstretch 2018-11-15_224828_mmbasicstretch Name your poison led edit: Added one more Stretch MMBasic edit2: All in one zip file Edited 2020-10-19 07:33 by led-bloon Miss you George |
I made an error 2 posts up 5.4.16 blit works but longstring does not work but 5.4.21 upwards longstring works but blit doesn't I've tried every version I can find from 5.4.21 upwards Peter if you'r watching this is there any easy way for me to modify version 5.4.16 to make longstring work? Edited 2020-10-19 18:46 by lew247 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11873 |
There is no change in the code for longstring or blit between these versions. This highlights the whole issue with the Picromite. It seems impossible to build a reliable version for any given combination of Raspbian and Pi type. Old version can't be modified as I don't have copies of older source - sorry. |
Thanks Peter You were right obviously longstring does work but the versions after 5.4.20 the amount of data longstring can handle was increased Blit for some reason doesn't work after 4.4.16 but I'll just use the earlier version not to worry I'll try and reduce the amount of data needed |
