Local Time 10:24 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CM2: IN functionality
bar1010
Posted: 07:00pm 14 Nov 2020
Would it be worthwhile to create the Oracle PL/SQL IN functionality?
Variable IN(2, 5, 12)
Replacing
Variable = 2 or variable = 5 or variable = 12
elk1984
Posted: 07:46pm 14 Nov 2020
Concat the values with |, do an INSTR?
If you wanted to be posh, you could pass an array and have the function do the concat
DIM contained AS Integer
contained = ValueIn("|2|5|12|","2")
END
FUNCTION ValueIn(valuesToCheck As String, valueContained As String) As Integer
 ValueIn = (INSTR(valuesToCheck,"|"+valueContained+"|")>0)
END FUNCTION
