Local Time 08:09 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : A suggestion - Pi
lew247
Posted: 09:19am 25 Nov 2020
The development of MM Basic on the Pi was stopped because the OS of Pi keeps changing and it's too hard to keep up with changes
I get that
But
If we are using MM Basic do we really need to keep the OS of the Pi updated?
Could someone with knowledge pick ONE version of the Pi OS and develop/update Pi-Cromite just for that version?
Any further updates to MM Basic would therefore easily be able to be ported to Pi-Cromite as the main OS for the Pi wouldn't have changed
The only stipulation would have to be that it was made clear that MM Basic will only work for that one version of PI OS and no other.
Not a problem as far as I can see
The only thing is -- can anyone do it?
I'm certain I'm not the only person that loved working MM Basic on the Pi Zero W and Pi 3+ / 4 it's the only version with built in Wi-Fi and Bluetooth  and the Wi-Fi is so so handy for so many things
Edited 2020-11-25 19:20 by lew247
goc30
Posted: 09:58am 25 Nov 2020
I agree with you. I think the rpi have too much potential to ignore them, especially if we compare an rpi zero with a cmm2, the rpi costs 5 times less and is 5 times faster, + memory capacity and video controller in hdmi
especially since the only advantage to use picromite is with the "lite" version of linux. The complete version has little interest and poses more problems than it brings advantages
Edited 2020-11-25 20:03 by goc30
Quazee137
Posted: 11:21am 25 Nov 2020
I too would like a lite linux + MMBasic on the Rpi as it expands on my use of
the HDMI. I would use MMBasic over Python. I can enjoy MMBasic's syntax
where as Python has quirks that unless you use it a lot an out of place space
or missing tab can have you in fits for days trying to debug it.
I have been using Geany and its highlighted text with MMBasic and it works great.
Tried Python with it. Now if I could have it highlight the needed syntaxed needed
space and tabs I would have less trouble. Wondering if there is a syntax parser
for Python that could catch the space/tab bit then it might be usable for me.
But ease of use/readability puts MMBasic at the top of my tools to use on my projects.
Now if a secure OS for the RPi that will not need to be updated along with MMBasic
could make the Rpi zero a goto board all I'd need to add is my custom hats that I
made for the MM170 Hat Stand by matherp with 3.5" and 4" displays.
I could use my current hats with the RPi zero and MMBasic that would give me
the HDMI out put as the cost of TV's (bigger screens) are getting cheaper.
Posted: 11:29am 25 Nov 2020
I've already said I will give the Picromite code to anyone that wants to take it on as long as they get Geoff's agreement and follow his licensing rules but I've given up on it and won't be looking at it any further. It needs three main components to be in sync to make a working version. Raspbian, ncurses, and PIGPIO. + you need to get a stable IDE that matches.
Posted: 02:08pm 25 Nov 2020
I just happen to have a spare Pi 2 at the moment. I'll put the Pi version of MMBasic on it and have a play. Any idea what the latest version is? Is it 5.4.16 for Stretch?
Posted: 05:28pm 25 Nov 2020
Ah - scrub that. I've just found what I think is 5.4.25 and a bit:
2018-11-17_085257_mmbasicstretch.zip
Stretch has 9 versions. Avilable here
rasbian-2017-08-17/ to raspbian-2019-04-09/
I assume that raspbian-2018-10-11/ or raspbian-2018-11-15/ would be the best to try.
goc30
Posted: 02:44am 26 Nov 2020
  matherp said  I've already said I will give the Picromite code to anyone that wants to take it on as long as they get Geoff's agreement and follow his licensing rules but I've given up on it and won't be looking at it any further. It needs three main components to be in sync to make a working version. Raspbian, ncurses, and PIGPIO. + you need to get a stable IDE that matches.
I had thought of another use of the Pi-Zero, it would be to be an intelligent graphics controller dedicated to the MMBadic and therefore to internally execute the graphics functions of the MMbasic defined in cmm2. there will be just a link type spi or 8/16 bits.
any Micromite could directly send the graphics instruction (formatted according to a defined protocol) to the Pi-Zero which would receive it in a FIFO stack and execute it on the hdmi screen.
Frank N. Furter
Posted: 07:49am 26 Nov 2020
...why not use CIRCLE like in this project?
https://github.com/randyrossi/bmc64
Annoyingly, my programming skills are not sufficient to realize such a thing.
A baremetal variant would be dreamlike!!!
Posted: 06:48pm 26 Nov 2020
  Frank N. Furter said  ...why not use CIRCLE like in this project?
That seems to be about BMC64.  What is CIRCLE?
  Frank N. Furter said  A baremetal variant would be dreamlike!!!
As has been said multiple times, it's a huge task.
Edited 2020-11-27 04:52 by JohnS
markboston36
Posted: 07:17pm 26 Nov 2020
what do you mean the OS keeps changing? its based on Debian. it only changes when there's an update to debian.
rspi org does support other types of OS's but raspbian/rasberry pi OS is the default.
Posted: 07:51pm 26 Nov 2020
  markboston36 said  what do you mean the OS keeps changing? its based on Debian. it only changes when there's an update to debian.
See matherp's post above.
If you like, ask him for the code, build it yourself on each of the RPIs, then test and see what happens.
Edited 2020-11-27 05:52 by JohnS
hitsware2
Posted: 07:56pm 26 Nov 2020
Definitely changes .
Based on Debian but adjusted to the hardware .
I use Stretch because Buster screws up my preferences .
my site
Posted: 08:40pm 26 Nov 2020
You can't / shouldn't ever even attempt to talk directly to the hardware on a Pi. No matter how much you think you need to. Some of it you can't anyway. :) How much that affects running MMBasic on a Pi I don't know. There are probably ways of running software cross-versions on Raspbian, but whether they are non-trivial I've no idea.
Raspbian definitely changes - as I pointed out, there were 9 releases of Stretch alone, though they will probably be updates to packages rather than to the OS itself.
PIGPIO has been provided with Raspbian for a while now.
Edited 2020-11-27 06:49 by Mixtel90
hitsware2
Posted: 09:02pm 26 Nov 2020
Someone does it at some time ......
my site
Posted: 11:15pm 26 Nov 2020
  hitsware2 said  >"You can't / shouldn't ever even attempt to talk
> directly to the hardware on a Pi."
See pi hardware interface
You participated:
  hitsware2 said  Would someone please elaborate on the " binary-blob " ?
Is there another term ?
Posted: 11:51pm 26 Nov 2020
I'm guessing the link should be this
Posted: 12:44am 27 Nov 2020
Oops, thanks.
Frank N. Furter
Posted: 07:49am 27 Nov 2020
CIRCLE is a development environment to program the Pi as BAREMETAL without any operating system:
CIRCLE
Frank
Posted: 08:31am 27 Nov 2020
But CIRCLE is a development environment - it provides libraries etc to enable pseudo bare metal programming. Effectively their own APIs. Those libraries are obviously breaking the rule that you don't talk directly to the hardware, only to the Raspbian APIs as that's the only official way to make things work. They have apparently attempted to write a new kernel, in effect. That's creditable, but there is already a working and supported official kernel. The only reason I can see to use CIRCLE is to use some of the hardware that isn't currently supported by Raspbian - and may therefore be changed or removed in the future without notice.
Note that even using CIRCLE your prog has to be compiled separately for each of the Pi versions. It's not cross-version. Talking to Raspbian, using the correct APIs, should *in theory* remove that requirement as the versions changes have already been taken care of.
Edited 2020-11-27 18:40 by Mixtel90
Posted: 10:06am 27 Nov 2020
  Mixtel90 said  Talking to Raspbian, using the correct APIs, should *in theory* remove that requirement as the versions changes have already been taken care of.
It doesn't, though, as matherp has pointed out.
It would if MMBasic didn't provide the I/O features it does.  Prefer it stripped down dramatically?
Edited 2020-11-27 20:08 by JohnS
