Local Time 05:24 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: The new 3D engine in action - check the video
Posted: 07:45pm 02 Dec 2020
https://youtu.be/JlzUSud4xC4
option explicit
option default none
mode 2,16
dim float phi=(1+sqr(5))/2
' data for location of verticies for verticesahedron of edge length 2
data 0,1,3*phi
data 0,1,-3*phi
data 0,-1,3*phi
data 0,-1,-3*phi
data 1,3*phi,0
data 1,-3*phi,0
data -1,3*phi,0
data -1,-3*phi,0
data 3*phi,0,1
data 3*phi,0,-1
data -3*phi,0,1
data -3*phi,0,-1
data 2,(1+2*phi),phi
data 2,(1+2*phi),-phi
data 2,-(1+2*phi),phi
data 2,-(1+2*phi),-phi
data -2,(1+2*phi),phi
data -2,(1+2*phi),-phi
data -2,-(1+2*phi),phi
data -2,-(1+2*phi),-phi
data (1+2*phi),phi,2
data (1+2*phi),phi,-2
data (1+2*phi),-phi,2
data (1+2*phi),-phi,-2
data -(1+2*phi),phi,2
data -(1+2*phi),phi,-2
data -(1+2*phi),-phi,2
data -(1+2*phi),-phi,-2
data phi,2,(1+2*phi)
data phi,2,-(1+2*phi)
data phi,-2,(1+2*phi)
data phi,-2,-(1+2*phi)
data -phi,2,(1+2*phi)
data -phi,2,-(1+2*phi)
data -phi,-2,(1+2*phi)
data -phi,-2,-(1+2*phi)
data 1,(2+phi),2*phi
data 1,(2+phi),-2*phi
data 1,-(2+phi),2*phi
data 1,-(2+phi),-2*phi
data -1,(2+phi),2*phi
data -1,(2+phi),-2*phi
data -1,-(2+phi),2*phi
data -1,-(2+phi),-2*phi
data (2+phi),2*phi,1
data (2+phi),2*phi,-1
data (2+phi),-2*phi,1
data (2+phi),-2*phi,-1
data -(2+phi),2*phi,1
data -(2+phi),2*phi,-1
data -(2+phi),-2*phi,1
data -(2+phi),-2*phi,-1
data 2*phi,1,(2+phi)
data 2*phi,1,-(2+phi)
data 2*phi,-1,(2+phi)
data 2*phi,-1,-(2+phi)
data -2*phi,1,(2+phi)
data -2*phi,1,-(2+phi)
data -2*phi,-1,(2+phi)
data -2*phi,-1,-(2+phi)
' 12 faces with 5 sides
data 0,28,36,40,32
data 33,41,37,29,1
data 34,42,38,30,2
data 3,31,39,43,35
data 4,12,44,45,13
data 15,47,46,14,5
data 17,49,48,16,6
data 7,18,50,51,19
data 8,20,52,54,22
data 23,55,53,21,9
data 26,58,56,24,10
data 25,57,59,27,11
' 20 faces with 6 sides
data 32,56,58,34,2,0
data 0,2,30,54,52,28
data 29,53,55,31,3,1
data 1,3,35,59,57,33
data 13,37,41,17,6,4
data 4,6,16,40,36,12
data 5,7,19,43,39,15
'data 14,38,42,18,7,5
data 22,46,47,23,9,8
data 8,9,21,45,44,20
data 10,11,27,51,50,26
data 24,48,49,25,11,10
data 36,28,52,20,44,12
data 13,45,21,53,29,37
data 14,46,22,54,30,38
data 39,31,55,23,47,15
data 16,48,24,56,32,40
data 41,33,57,25,49,17
data 42,34,58,26,50,18
data 19,51,27,59,35,43
dim float q1(4)
dim integer i, j, nf=31, nv=60, camera=1
dim float vertices(2,59)
' read in the coordinates of the verticies and scale
for j=0 to 59
for i=0 to 2
  read vertices(i,j)
  vertices(i,j)=vertices(i,j)*50
next i
next j
'math scale vertices(),50,vertices()
dim integer faces(173)
for i=0 to 173
 read faces(i)
next i
dim integer fc(30)=  (5,5,5,5,5,5,5,5,5,5,5,5,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6,6)
dim integer colours(2)=(rgb(red),rgb(white),rgb(black))
dim integer edge(30)=(2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2)
dim integer fill(30)=(0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1)
math q_create rad(2),1,0.5,0.25,q1()
draw3d create 1, nv,nf, camera, vertices(), fc(), faces(), colours(), edge(), fill()
draw3d camera 1,800,mm.hres\2,mm.vres\2
'draw3d diagnose 1,mm.hres\2,mm.vres\2,1000
page write 1
draw3d show 1,mm.hres\2,mm.vres\2,1000,1
do
draw3d rotate q1(),1
draw3d reset 1
page copy 1 to 0,b
loop
CircuitGizmos
Posted: 07:48pm 02 Dec 2020
Oh, no! I hope you can find your missing pentagon!
:D
That's pretty impressive!
JoOngle
Posted: 07:52pm 02 Dec 2020
Mind Blown!
Anyone willing to make a Blender or .stl /.blend /.obj importer for it? :D
I'm pretty good at 3D modelling, but I pretty much suck at math.
mkopack73
Posted: 10:05pm 02 Dec 2020
Yeah would love to see some sort of standard 3D model file format for the CMM2, (or a reader that can take in a standard modern 3D file) and a library for reading it in...
LeoNicolas
Posted: 05:09am 03 Dec 2020
JoOnlge, could you share here some files with a low poly model and a screenshot of the rendered polygon? (ply, obj, ...)
jirsoft
Posted: 09:52am 03 Dec 2020
I think at least standard PLY format could be used as first usable file type for 3D on CMM2:
PLY format
Jiri
mclout999
Posted: 01:41pm 03 Dec 2020
  jirsoft said  I think at least standard PLY format could be used as first usable file type for 3D on CMM2:
PLY format
What kid of PC apps are available to work with this format. It would be good to be able to design objects on a PC.
EDIT:  I did some searching and Blender and other can use the format.  I have it on my portable apps install so I will play with that.
Edited 2020-12-03 23:50 by mclout999
JoOngle
Posted: 05:11pm 03 Dec 2020
@LeoNicolas.
Yes of course.
I made a quick 1-hour 3D character (all I had time for, sorry for the crudity of the model).
But it's free, for all to download, experiment, test, make a game with, alter, build on, tear apart - as you wish.
CMM2 Low Poly Model
And if that link didn't work, here's another one:
Find it here
Edited 2020-12-04 03:18 by JoOngle
Posted: 08:55am 04 Dec 2020
JoOngle
Can you generate either the phy or stl in ascii format so I can see if the 3D engine will handle the model
JoOngle
Posted: 01:23pm 04 Dec 2020
@Matherp
Yes - Compressed package updated with PLY as ASCII, with and without Normals(faces).
Low-Poly-Free-TestCharacter
Posted: 05:58pm 04 Dec 2020
IT WORKS
362 Vertices and 361 faces
Render time 10mSec!
https://youtu.be/jYdevBvl73k
Needed a mod to the firmware to overcome a limitation of 256 vertices and faces so
V5.06.00b14 posted:
The model itself had a duff face so I've also included a new command in the firmware
DRAW3D SET FLAGS n, flag, startface0, numberoffaces0 [, startface1, numberoffaces1 [,....]]
This allows you to control the way a face is displayed.
flag is a bitmap and has values as follows
bit-0  ' don't display the face if set
bit-1  ' display the face in red allowing you to visualise which each face is
bit-2  ' reverse the normal vector
I used the flags setting faces red to do a repeated binary chop of the faces until I determined the bad definition was face 132.
The model has lots of faces with the surface normal the wrong way round so rather than trying to correct them all I've just used the option on the SHOW command to base the render solely on Painter's algorithm
Code for the demo
OPTION EXPLICIT
OPTION DEFAULT NONE
DATA 362
DATA 361
DATA -0.379360,0.389173,0.004961
DATA -0.379360,0.233113,0.004961
DATA -0.188428,0.123262,0.004961
DATA -0.188428,0.531739,0.004961
DATA -0.072191,0.222310,0.004973
DATA -0.047370,0.389173,0.004961
DATA -0.344274,0.007309,0.004961
DATA -0.188428,-0.092776,0.004961
DATA -0.047370,-0.092776,0.004961
DATA -0.300213,0.268194,0.167819
DATA -0.300213,0.356920,0.167819
DATA -0.344802,0.350181,0.315249
DATA -0.344802,0.225429,0.298482
DATA -0.191660,0.437974,0.167819
DATA -0.225357,0.411155,0.330566
DATA -0.191660,0.205740,0.167819
DATA -0.188428,-0.092776,0.073241
DATA -0.344274,0.007309,0.073241
DATA -0.122131,0.260776,0.167819
DATA -0.047370,-0.092776,0.073241
DATA -0.096576,0.356920,0.167819
DATA -0.357694,0.160042,0.598374
DATA -0.357694,0.334641,0.598374
DATA -0.304555,0.326214,0.827897
DATA -0.304555,0.170154,0.827897
DATA -0.060513,0.334641,0.455617
DATA -0.116905,0.145445,0.482640
DATA -0.096581,0.157107,0.621006
DATA -0.040722,0.356989,0.613865
DATA -0.225357,0.137617,0.286680
DATA -0.147194,0.215000,0.297080
DATA -0.110940,0.350181,0.315249
DATA -0.187957,0.113257,0.768829
DATA -0.315788,0.170154,0.901688
DATA -0.319766,0.167037,1.018321
DATA -0.255152,0.057362,0.975206
DATA -0.110650,0.090740,0.713959
DATA -0.137707,-0.011474,0.912633
DATA -0.194088,0.426330,0.503889
DATA -0.210049,0.446231,0.697688
DATA -0.195400,0.075364,0.526995
DATA -0.212395,0.128631,0.700298
DATA -0.075786,-0.044187,1.917807
DATA -0.002957,-0.081509,1.902842
DATA -0.002957,-0.108377,1.870530
DATA -0.066120,-0.099602,1.835642
DATA -0.318865,0.264565,1.010304
DATA -0.297236,0.290714,1.129285
DATA -0.288821,0.194878,1.144383
DATA -0.002957,-0.034833,0.898962
DATA -0.117945,0.023649,1.120933
DATA -0.002957,-0.014532,1.123231
DATA -0.315788,0.326214,0.901688
DATA -0.244262,0.476706,0.828632
DATA -0.147566,0.493777,0.787052
DATA -0.140880,0.504056,0.905703
DATA -0.262255,0.439912,0.980968
DATA -0.194575,0.305538,1.626750
DATA -0.087488,0.424681,1.653096
DATA -0.149058,0.476287,1.769081
DATA -0.327468,0.283027,1.744901
DATA -0.008203,0.375321,0.696224
DATA -0.068663,0.456001,0.797412
DATA -0.002957,0.083247,0.658685
DATA -0.002957,0.157451,0.597732
DATA -0.234039,0.371484,1.102735
DATA -0.111811,0.406216,1.069015
DATA -0.127071,0.442219,1.241262
DATA -0.217422,0.389940,1.287812
DATA -0.291448,0.342279,1.267611
DATA -0.252099,0.231323,1.285561
DATA -0.002957,0.405644,1.045036
DATA -0.002957,0.431072,1.238051
DATA 0.006364,0.463636,0.852790
DATA -0.224214,0.099127,1.071018
DATA -0.114606,0.507336,1.439379
DATA -0.205350,0.487452,1.455957
DATA -0.345402,0.482801,1.380065
DATA -0.334866,0.376492,1.291468
DATA -0.002957,0.488894,1.415226
DATA -0.104362,0.117189,1.256332
DATA -0.002957,0.103303,1.261941
DATA -0.063222,0.195233,1.576923
DATA -0.150337,0.248939,1.554561
DATA -0.177429,0.214422,1.617020
DATA -0.073851,0.151092,1.608612
DATA -0.186886,0.138747,1.258185
DATA -0.002957,0.140862,1.607076
DATA -0.202958,-0.074643,1.658773
DATA -0.119020,-0.072714,1.591007
DATA -0.074692,0.428356,1.571604
DATA -0.164757,0.397091,1.547789
DATA -0.098648,0.114806,1.475875
DATA -0.181202,0.211915,1.463738
DATA -0.398079,0.487595,1.479926
DATA -0.002957,0.103968,1.456772
DATA -0.002957,0.432364,1.572940
DATA -0.002957,0.429364,1.653985
DATA -0.271612,0.289241,1.482062
DATA -0.408993,0.377602,1.510960
DATA -0.602881,0.384554,1.487668
DATA -0.602646,0.495072,1.436344
DATA -0.596949,0.487155,1.329264
DATA -0.323371,0.384449,1.525717
DATA -0.393181,0.288377,1.479032
DATA -0.339974,0.264333,1.375487
DATA -0.603892,0.294344,1.442583
DATA -0.900347,0.334644,1.437974
DATA -0.905187,0.404108,1.459037
DATA -0.604835,0.267477,1.326850
DATA -0.900723,0.313956,1.383904
DATA -0.600755,0.377663,1.285929
DATA -0.904339,0.398802,1.347189
DATA -0.897576,0.483113,1.385031
DATA -1.004832,0.514249,1.383402
DATA -1.011595,0.415597,1.345559
DATA -0.899849,0.489209,1.435059
DATA -1.012443,0.420903,1.457407
DATA -1.007105,0.520345,1.433429
DATA -1.007979,0.315613,1.382274
DATA -1.182184,0.394566,1.373525
DATA -1.176931,0.305318,1.393395
DATA -1.007603,0.336302,1.436344
DATA -1.220113,0.353794,1.427750
DATA -1.242188,0.422756,1.444072
DATA -0.947814,0.243802,1.387684
DATA -0.901795,0.292021,1.388675
DATA -0.901419,0.293682,1.446544
DATA -0.947437,0.245463,1.445553
DATA -1.040362,0.200814,1.448129
DATA -1.050409,0.276098,1.449535
DATA -1.202093,0.506682,1.395307
DATA -1.229064,0.497859,1.423367
DATA -1.050680,0.261165,1.410507
DATA -1.040633,0.199615,1.406360
DATA -0.002957,0.186534,1.578548
DATA -0.232839,0.365737,1.555737
DATA -0.245977,0.293756,1.549688
DATA -0.225090,0.518196,1.903408
DATA -0.488844,0.345532,1.866283
DATA -0.002957,0.557568,1.751750
DATA -0.002957,0.638326,1.875633
DATA -0.288527,0.096293,1.684966
DATA -0.199190,0.003402,1.875237
DATA -0.159336,-0.018665,1.919760
DATA -0.449903,0.083576,1.812538
DATA -0.361025,0.302378,1.999151
DATA -0.395589,0.033628,1.954215
DATA -0.226882,-0.016186,2.043459
DATA -0.091346,-0.040276,2.092963
DATA -0.266352,-0.105650,1.773366
DATA -0.120014,-0.183914,1.709304
DATA -0.002957,-0.090258,1.570264
DATA -0.368176,0.016043,2.114511
DATA -0.335528,-0.066181,2.086433
DATA -0.182615,0.523903,2.063726
DATA -0.317187,0.374948,2.225507
DATA -0.364419,0.329891,2.210448
DATA -0.002957,0.668784,2.096423
DATA -0.002957,0.587981,2.294384
DATA -0.002957,0.465092,2.384136
DATA -0.266393,0.288139,2.349916
DATA -0.313082,0.244150,2.342466
DATA -0.304908,0.014978,2.259953
DATA -0.002957,-0.210245,1.675899
DATA -0.002957,-0.145271,2.191161
DATA -0.152290,-0.122570,2.197897
DATA -0.085615,0.029052,2.337431
DATA -0.002957,0.009110,2.332926
DATA -0.201430,0.102329,2.361432
DATA -0.441877,0.370919,2.242938
DATA -0.393230,0.435021,2.261176
DATA -0.431725,0.466106,2.395273
DATA -0.500593,0.371474,2.361792
DATA -0.002957,-0.161782,2.090673
DATA -0.221996,0.183704,2.386207
DATA -0.091185,0.263378,2.413061
DATA -0.002957,0.291527,2.422412
DATA -0.417446,0.397283,2.459735
DATA -0.478491,0.336459,2.436249
DATA -0.323227,0.320639,2.460103
DATA -0.381775,0.272113,2.433417
DATA -0.002957,-0.198377,1.879622
DATA -0.094375,-0.210841,1.846853
DATA -0.002957,-0.277519,1.747358
DATA -0.105406,-0.254375,1.781103
DATA 0.373447,0.389173,0.004961
DATA 0.182515,0.531739,0.004961
DATA 0.182515,0.123262,0.004961
DATA 0.373447,0.233113,0.004961
DATA 0.041456,0.389173,0.004961
DATA 0.066277,0.222310,0.004973
DATA 0.182515,-0.092776,0.004961
DATA 0.338361,0.007309,0.004961
DATA 0.041456,-0.092776,0.004961
DATA 0.294299,0.268194,0.167819
DATA 0.338888,0.225429,0.298482
DATA 0.338888,0.350181,0.315249
DATA 0.294299,0.356920,0.167819
DATA 0.219444,0.411155,0.330566
DATA 0.185747,0.437974,0.167819
DATA 0.338361,0.007309,0.073241
DATA 0.182515,-0.092776,0.073241
DATA 0.185747,0.205740,0.167819
DATA 0.041456,-0.092776,0.073241
DATA 0.116217,0.260776,0.167819
DATA 0.090662,0.356920,0.167819
DATA 0.351781,0.160042,0.598374
DATA 0.298641,0.170154,0.827897
DATA 0.298641,0.326214,0.827897
DATA 0.351781,0.334641,0.598374
DATA 0.054600,0.334641,0.455617
DATA 0.034808,0.356989,0.613865
DATA 0.090667,0.157107,0.621006
DATA 0.110991,0.145445,0.482640
DATA 0.219444,0.137617,0.286680
DATA 0.105027,0.350181,0.315249
DATA 0.141281,0.215000,0.297080
DATA 0.182043,0.113257,0.768829
DATA 0.249238,0.057362,0.975206
DATA 0.313853,0.167037,1.018321
DATA 0.309874,0.170154,0.901688
DATA 0.104736,0.090740,0.713959
DATA 0.131793,-0.011474,0.912633
DATA 0.188175,0.426330,0.503889
DATA 0.204136,0.446231,0.697688
DATA 0.206481,0.128631,0.700298
DATA 0.189487,0.075364,0.526995
DATA 0.069872,-0.044187,1.917807
DATA 0.060206,-0.099602,1.835642
DATA 0.282907,0.194878,1.144383
DATA 0.291323,0.290714,1.129285
DATA 0.312951,0.264565,1.010304
DATA 0.112032,0.023649,1.120933
DATA 0.309874,0.326214,0.901688
DATA 0.238348,0.476706,0.828632
DATA 0.256341,0.439912,0.980968
DATA 0.147392,0.496192,0.920286
DATA 0.141652,0.493777,0.787052
DATA 0.188661,0.305538,1.626750
DATA 0.321555,0.283027,1.744901
DATA 0.143145,0.476287,1.769081
DATA 0.081574,0.424681,1.653096
DATA 0.062749,0.456001,0.797412
DATA 0.228126,0.371484,1.102735
DATA 0.211509,0.389940,1.287812
DATA 0.121157,0.442219,1.241262
DATA 0.105897,0.406216,1.069015
DATA 0.246185,0.231323,1.285561
DATA 0.285534,0.342279,1.267611
DATA 0.218301,0.099127,1.071018
DATA 0.199437,0.487452,1.455957
DATA 0.108693,0.507336,1.439379
DATA 0.328952,0.376492,1.291468
DATA 0.339488,0.482801,1.380065
DATA 0.098448,0.117189,1.256332
DATA 0.057309,0.195233,1.576923
DATA 0.067937,0.151092,1.608612
DATA 0.171516,0.214422,1.617020
DATA 0.144423,0.248939,1.554561
DATA 0.180973,0.138747,1.258185
DATA 0.113106,-0.072714,1.591007
DATA 0.197045,-0.074643,1.658773
DATA 0.158843,0.397091,1.547789
DATA 0.068778,0.428356,1.571604
DATA 0.092735,0.114806,1.475875
DATA 0.175288,0.211915,1.463738
DATA 0.392166,0.487595,1.479926
DATA 0.265699,0.289241,1.482062
DATA 0.596732,0.495072,1.436344
DATA 0.596967,0.384554,1.487668
DATA 0.403080,0.377602,1.510960
DATA 0.591036,0.487155,1.329264
DATA 0.317458,0.384449,1.525717
DATA 0.387267,0.288377,1.479032
DATA 0.334060,0.264333,1.375487
DATA 0.899274,0.404108,1.459037
DATA 0.894433,0.334644,1.437974
DATA 0.597979,0.294344,1.442583
DATA 0.894809,0.313956,1.383904
DATA 0.598921,0.267477,1.326850
DATA 0.594842,0.377663,1.285929
DATA 0.898426,0.398802,1.347189
DATA 1.005681,0.415597,1.345559
DATA 0.998918,0.514249,1.383402
DATA 0.891663,0.483113,1.385031
DATA 0.893936,0.489209,1.435059
DATA 1.001192,0.520345,1.433429
DATA 1.006530,0.420903,1.457407
DATA 1.002065,0.315613,1.382274
DATA 1.171017,0.305318,1.393395
DATA 1.176270,0.394566,1.373525
DATA 1.236274,0.422756,1.444072
DATA 1.214199,0.353794,1.427750
DATA 1.001689,0.336302,1.436344
DATA 0.895881,0.292021,1.388675
DATA 0.941900,0.243802,1.387684
DATA 0.895505,0.293682,1.446544
DATA 0.941524,0.245463,1.445553
DATA 1.044495,0.276098,1.449535
DATA 1.034448,0.200814,1.448129
DATA 1.223150,0.497859,1.423367
DATA 1.196179,0.506682,1.395307
DATA 1.044767,0.261165,1.410507
DATA 1.034719,0.199615,1.406360
DATA 0.226925,0.365737,1.555737
DATA 0.240064,0.293756,1.549688
DATA 0.482931,0.345532,1.866283
DATA 0.219177,0.518196,1.903408
DATA 0.282613,0.096293,1.684966
DATA 0.153423,-0.018665,1.919760
DATA 0.193276,0.003402,1.875237
DATA 0.443990,0.083576,1.812538
DATA 0.389676,0.033628,1.954215
DATA 0.355111,0.302378,1.999151
DATA 0.085432,-0.040276,2.092963
DATA 0.220968,-0.016186,2.043459
DATA 0.260438,-0.105650,1.773366
DATA 0.114100,-0.183914,1.709304
DATA 0.329614,-0.066181,2.086433
DATA 0.362263,0.016043,2.114511
DATA 0.358506,0.329891,2.210448
DATA 0.311273,0.374948,2.225507
DATA 0.176701,0.523903,2.063726
DATA 0.260480,0.288139,2.349916
DATA 0.298994,0.014978,2.259953
DATA 0.307168,0.244150,2.342466
DATA 0.079702,0.029052,2.337431
DATA 0.146377,-0.122570,2.197897
DATA 0.195517,0.102329,2.361432
DATA 0.435964,0.370919,2.242938
DATA 0.494679,0.371474,2.361792
DATA 0.425812,0.466106,2.395273
DATA 0.387316,0.435021,2.261176
DATA 0.216082,0.183704,2.386207
DATA 0.085271,0.263378,2.413061
DATA 0.472578,0.336459,2.436249
DATA 0.411532,0.397283,2.459735
DATA 0.317313,0.320639,2.460103
DATA 0.375861,0.272113,2.433417
DATA 0.088461,-0.210841,1.846853
DATA 0.099493,-0.254375,1.781103
DATA -0.022537,0.559884,0.832170
DATA 0.069308,0.553783,0.760912
DATA -0.031686,0.527362,0.674901
DATA 0.199427,0.723933,0.560435
DATA 0.006664,0.668892,0.439200
DATA -0.137371,0.551012,0.730322
DATA 0.009815,0.881898,0.761479
DATA 0.052449,1.069262,0.486229
DATA 0.162836,0.985650,0.364496
DATA -0.195960,0.789529,0.590455
DATA 0.051269,0.956444,0.292985
DATA 0.105354,1.139440,0.306910
DATA 0.061822,1.134228,0.277364
DATA -0.063763,1.006549,0.351095
DATA 0.016627,1.143001,0.305339
DATA 0.060584,1.222685,0.297914
DATA 0.043490,1.226004,0.308495
DATA 0.061933,1.153231,0.362449
DATA 0.077049,1.224657,0.309089
DATA 0.060626,1.229873,0.330095
DATA 87,152,261
DATA 0,1,2,3
DATA 3,2,4,5
DATA 1,6,7,2
DATA 2,7,8,4
DATA 9,10,11,12
DATA 10,13,14,11
DATA 9,15,16,17
DATA 15,18,19,16
DATA 5,4,18,20
DATA 6,1,9,17
DATA 7,6,17,16
DATA 3,5,20,13
DATA 0,3,13,10
DATA 4,8,19,18
DATA 8,7,16,19
DATA 1,0,10,9
DATA 21,22,23,24
DATA 25,26,27,28
DATA 15,9,12,29
DATA 20,18,30,31
DATA 18,15,29,30
DATA 13,20,31,14
DATA 32,33,34,35
DATA 36,32,35,37
DATA 38,25,28,39
DATA 22,38,39,23
DATA 26,40,41,27
DATA 40,21,24,41
DATA 42,43,44,45
DATA 34,46,47,48
DATA 49,37,50,51
DATA 33,52,46,34
DATA 53,54,55,56
DATA 52,53,56,46
DATA 57,58,59,60
DATA 54,28,61,62
DATA 36,37,49,63
DATA 28,27,64,61
DATA 65,66,67,68
DATA 48,47,69,70
DATA 66,71,72,67
DATA 56,55,66,65
DATA 46,56,65,47
DATA 55,73,71,66
DATA 37,35,74,50
DATA 35,34,48,74
DATA 68,67,75,76
DATA 69,68,77,78
DATA 67,72,79,75
DATA 47,65,68,69
DATA 51,50,80,81
DATA 82,83,84,85
DATA 50,74,86,80
DATA 74,48,70,86
DATA 27,36,63,64
DATA 55,54,62,73
DATA 87,85,88,89
DATA 23,39,53,52
DATA 39,28,54,53
DATA 24,23,52,33
DATA 27,41,32,36
DATA 41,24,33,32
DATA 76,75,90,91
DATA 92,93,83,82
DATA 68,76,94,77
DATA 81,80,92,95
DATA 90,96,97,58
DATA 80,86,93,92
DATA 86,70,98,93
DATA 29,12,21,40
DATA 30,29,40,26
DATA 11,14,38,22
DATA 14,31,25,38
DATA 31,30,26,25
DATA 12,11,22,21
DATA 94,99,100,101
DATA 77,94,101,102
DATA 103,98,104,99
DATA 98,70,105,104
DATA 76,103,99,94
DATA 70,69,78,105
DATA 100,106,107,108
DATA 106,109,110,107
DATA 78,77,102,111
DATA 104,105,109,106
DATA 99,104,106,100
DATA 105,78,111,109
DATA 112,113,114,115
DATA 116,108,117,118
DATA 109,111,112,110
DATA 102,101,116,113
DATA 101,100,108,116
DATA 111,102,113,112
DATA 119,115,120,121
DATA 117,122,123,124
DATA 110,119,125,126
DATA 108,107,122,117
DATA 110,112,115,119
DATA 113,116,118,114
DATA 127,126,125,128
DATA 107,110,126,127
DATA 122,107,127,128
DATA 122,128,129,130
DATA 121,120,124,123
DATA 120,131,132,124
DATA 114,118,132,131
DATA 118,117,124,132
DATA 115,114,131,120
DATA 122,119,121,123
DATA 133,130,129,134
DATA 128,125,134,129
DATA 119,122,130,133
DATA 125,119,133,134
DATA 95,92,82,135
DATA 136,91,83,137
DATA 91,90,58,57
DATA 135,82,85,87
DATA 60,59,138,139
DATA 59,140,141,138
DATA 83,91,57,84
DATA 103,76,91,136
DATA 75,79,96,90
DATA 98,103,136,137
DATA 93,98,137,83
DATA 85,84,142,88
DATA 45,143,144,42
DATA 58,97,140,59
DATA 84,57,60,142
DATA 145,139,146,147
DATA 42,144,148,149
DATA 88,142,145,150
DATA 89,88,150,151
DATA 3,87,89,152
DATA 142,60,139,145
DATA 143,147,153,154
DATA 146,155,156,157
DATA 138,141,158,155
DATA 139,138,155,146
DATA 150,145,147,143
DATA 151,150,143,45
DATA 156,159,160,161
DATA 153,157,162,163
DATA 143,154,148,144
DATA 164,152,89,151
DATA 147,146,157,153
DATA 155,158,159,156
DATA 165,166,167,168
DATA 166,163,169,167
DATA 170,171,172,173
DATA 154,153,163,166
DATA 149,166,165,174
DATA 175,176,167,169
DATA 167,176,177,168
DATA 163,162,175,169
DATA 161,160,177,176
DATA 162,161,176,175
DATA 149,148,154,166
DATA 173,172,178,179
DATA 171,180,178,172
DATA 180,181,179,178
DATA 181,170,173,179
DATA 162,157,170,181
DATA 161,162,181,180
DATA 156,161,180,171
DATA 157,156,171,170
DATA 45,44,182,183
DATA 182,184,185,183
DATA 43,42,149,174
DATA 151,45,183,185
DATA 164,151,185,184
DATA 186,187,188,189
DATA 187,190,191,188
DATA 189,188,192,193
DATA 188,191,194,192
DATA 195,196,197,198
DATA 198,197,199,200
DATA 195,201,202,203
DATA 203,202,204,205
DATA 190,206,205,191
DATA 193,201,195,189
DATA 192,202,201,193
DATA 187,200,206,190
DATA 186,198,200,187
DATA 191,205,204,194
DATA 194,204,202,192
DATA 189,195,198,186
DATA 207,208,209,210
DATA 211,212,213,214
DATA 203,215,196,195
DATA 206,216,217,205
DATA 205,217,215,203
DATA 200,199,216,206
DATA 218,219,220,221
DATA 222,223,219,218
DATA 224,225,212,211
DATA 210,209,225,224
DATA 214,213,226,227
DATA 227,226,208,207
DATA 228,229,44,43
DATA 220,230,231,232
DATA 49,51,233,223
DATA 221,220,232,234
DATA 235,236,237,238
DATA 234,232,236,235
DATA 239,240,241,242
DATA 238,243,61,212
DATA 222,63,49,223
DATA 212,61,64,213
DATA 244,245,246,247
DATA 230,248,249,231
DATA 247,246,72,71
DATA 236,244,247,237
DATA 232,231,244,236
DATA 237,247,71,73
DATA 223,233,250,219
DATA 219,250,230,220
DATA 245,251,252,246
DATA 249,253,254,245
DATA 246,252,79,72
DATA 231,249,245,244
DATA 51,81,255,233
DATA 256,257,258,259
DATA 233,255,260,250
DATA 250,260,248,230
DATA 213,64,63,222
DATA 237,73,243,238
DATA 87,261,262,257
DATA 209,234,235,225
DATA 225,235,238,212
DATA 208,221,234,209
DATA 213,222,218,226
DATA 226,218,221,208
DATA 251,263,264,252
DATA 265,256,259,266
DATA 245,254,267,251
DATA 81,95,265,255
DATA 264,242,97,96
DATA 255,265,266,260
DATA 260,266,268,248
DATA 215,227,207,196
DATA 217,214,227,215
DATA 197,210,224,199
DATA 199,224,211,216
DATA 216,211,214,217
DATA 196,207,210,197
DATA 267,269,270,271
DATA 254,272,269,267
DATA 273,271,274,268
DATA 268,274,275,248
DATA 251,267,271,273
DATA 248,275,253,249
DATA 270,276,277,278
DATA 278,277,279,280
DATA 253,281,272,254
DATA 274,278,280,275
DATA 271,270,278,274
DATA 275,280,281,253
DATA 282,283,284,285
DATA 286,287,288,276
DATA 280,279,282,281
DATA 272,285,286,269
DATA 269,286,276,270
DATA 281,282,285,272
DATA 289,290,291,283
DATA 288,292,293,294
DATA 279,295,296,289
DATA 276,288,294,277
DATA 279,289,283,282
DATA 285,284,287,286
DATA 297,298,296,295
DATA 277,297,295,279
DATA 294,298,297,277
DATA 294,299,300,298
DATA 290,293,292,291
DATA 291,292,301,302
DATA 284,302,301,287
DATA 287,301,292,288
DATA 283,291,302,284
DATA 294,293,290,289
DATA 303,304,300,299
DATA 298,300,304,296
DATA 289,303,299,294
DATA 296,304,303,289
DATA 95,135,256,265
DATA 305,306,259,263
DATA 263,239,242,264
DATA 135,87,257,256
DATA 240,307,308,241
DATA 241,308,141,140
DATA 259,258,239,263
DATA 273,305,263,251
DATA 252,264,96,79
DATA 268,306,305,273
DATA 266,259,306,268
DATA 257,262,309,258
DATA 229,228,310,311
DATA 242,241,140,97
DATA 258,309,240,239
DATA 312,313,314,307
DATA 228,315,316,310
DATA 262,317,312,309
DATA 261,318,317,262
DATA 309,312,307,240
DATA 311,319,320,313
DATA 314,321,322,323
DATA 308,323,158,141
DATA 307,314,323,308
DATA 317,311,313,312
DATA 318,229,311,317
DATA 322,324,160,159
DATA 320,325,326,321
DATA 311,310,316,319
DATA 164,318,261,152
DATA 313,320,321,314
DATA 323,322,159,158
DATA 165,168,327,328
DATA 328,327,329,325
DATA 330,331,332,333
DATA 319,328,325,320
DATA 315,174,165,328
DATA 334,329,327,335
DATA 327,168,177,335
DATA 325,329,334,326
DATA 324,335,177,160
DATA 326,334,335,324
DATA 315,328,319,316
DATA 331,336,337,332
DATA 333,332,337,338
DATA 338,337,336,339
DATA 339,336,331,330
DATA 326,339,330,321
DATA 324,338,339,326
DATA 322,333,338,324
DATA 321,330,333,322
DATA 229,340,182,44
DATA 182,340,341,184
DATA 43,174,315,228
DATA 318,341,340,229
DATA 164,184,341,318
DATA 243,73,342,343
DATA 344,343,345,346
DATA 61,243,343,344
DATA 62,61,344,347
DATA 73,62,347,342
DATA 345,348,349,350
DATA 347,344,346,351
DATA 343,342,348,345
DATA 342,347,351,348
DATA 352,350,353,354
DATA 348,351,355,349
DATA 346,345,350,352
DATA 351,346,352,355
DATA 356,354,357,358
DATA 355,352,354,356
DATA 350,349,359,353
DATA 349,355,356,359
DATA 357,360,361,358
DATA 353,359,361,360
DATA 359,356,358,361
DATA 354,353,360,357
DIM INTEGER i, nv, nf, camera=1, n=1, face_x_vert
read nv, nf
DIM FLOAT  vertices(2,nv-1), q(4), yaw=rad(1)
DIM INTEGER facecount(nf-1), edge(nf-1), fill(nf-1)
dim integer colours(1)=(rgb(white),rgb(blue))
for i=0 to nv-1
read vertices(0,i), vertices(1,i), vertices(2,i)
next i
math scale vertices(),200,vertices()
for i=0 to nf-1
 fill(i)=1
 edge(i)=0
 facecount(i)=4
next i
facecount(0)=3
face_x_vert=math(sum facecount())
dim integer faces(face_x_vert-1)
for i=0 to face_x_vert-1
 read faces(i)
next i
page write 1
draw3d create n, nv, nf, camera, vertices(), facecount(), faces(), colours(), edge(), fill()
math q_create rad(-90),1,0,0,q()
draw3d rotate q(),n
draw3d reset n
draw3d camera camera, 500,,250
draw3d show 1,0,0,600
draw3d set flag 1,1,132,1
do
math q_euler yaw,0,0,q()
draw3d rotate q(),n
print @(0,0)(deg(yaw) mod 360)
draw3d show 1,0,0,600,1
page copy 1 to 0,b
inc yaw,rad(1)
loop
Edited 2020-12-05 04:08 by matherp
JoOngle
Posted: 06:33pm 04 Dec 2020
That's simply awesome!
It looks so smooth too.
How do you think it would handle vertex animation? Let's say we made 8 poses (same character, but with 8 new vertex positions so to make a running loop)?
And (perhaps dreaming here - but saving on animation), could it be possible
for a routine to "interpolate" between 2-3 poses? For example move the vertices
from POSE A - to POSE B. And set a number of motion steps between them so less memory and less vertice pose characters would be needed?
In animation, we use extremes and in-betweens, the extremes are poses like "Legs far apart", "Legs-crosses" and lastly "Legs far appart, but mirrored", these are 3 extremes used for a walk animation. In-betweens are the missing movement frames between POS A- B - C, let's say it makes 2 interpolations or 3 inbetween each extreme pose.
Thanks for your insane efforts.
*Edit* Oh and yes, for the "duff faces", my bad - I used the "Mirror-modifier" in Blender, I guess when it Mirrors, it doesn't automatically take the mirrored part and unifies the faces to outside faces.
I should have checked for that when I delivered the model.
Edited 2020-12-05 04:38 by JoOngle
Posted: 06:51pm 04 Dec 2020
Check this one out
1335 vertices and 2452 faces rendered in 113mSec
JoOngle
Posted: 07:42pm 04 Dec 2020
I had some time on my hand since it's friday, so I have made some .ply poses available to you all, feel free to experiment (hopefully this time, the model is properly clean of double vertices and normals should be outside on all faces):
Since the animation test was specifically made for CMM2 type of export/import animation,
I had no way to test if it animates perfectly, so this is a trial and error.
.Blend files and a fully rigged character is included, you're free to improve on it
fix it, debug, add to it, use it in your games etc. GPL license all the way.
Animation .ply test files
Paul_L
Posted: 10:37pm 04 Dec 2020
  matherp said  Check this one out
Very nice, only it needs a little more dihedral for stability. Just don't add too much or you'll get a Dutch Roll like all of the early B707-100 aircraft.
Paul in NY
Posted: 05:48pm 05 Dec 2020
New video to check out:
https://youtu.be/nWljj64qmgs
This new capability uses the dot-product of the surface normal of each face with the vector to a notional lighting source to attenuate the colour. The code allows the MMBasic programmer to set an "ambient" level of light which will be there regardless. In the example this is set to a low level
Posted: 10:13am 06 Dec 2020
One more video
https://youtu.be/mEtwfwLlpaY
16-bit colour, 1335 vertices, 2452 faces and programmed lighting. The number top left shows the render time in milliseconds
Edited 2020-12-06 20:14 by matherp
LeoNicolas
Posted: 05:42pm 06 Dec 2020
  matherp said  New video to check out:
Peter
This is an impressive example of what the new API can do. Amazing.
I'm following the new features and examples but I'm not having time to play with them
Coresoap
Posted: 10:30am 11 Dec 2020
Hi, can anybody please post the routine to load the ply files to use them with the new commands. Thanks a lot.
Best regards Mike
