Local Time 06:24 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Nunchuk Problem?
toml_12953
Posted: 11:43am 08 Dec 2020
I'm trying to get a feel for the nunchuk and have a Wii nunchuk plugged into the front panel. The following program works fine:
wii nunchuk open
do
 ? nunchuk(jx);@(120);nunchuk(jy)
' ? nunchuk(ax);@(120);nunchuk(ay);@(240);nunchuk(az)
loop until nunchuk(z)=1 or nunchuk(c)=1
but if I remove the apostrophe from line four, the program prints some zeroes and stops without me pressing anything. Is this working right? If so my understanding of the nunchuk function is way off. I thought it should print the xy coordinates of the analog stick then print the x,y,z coordinates of the orientation and loop until I press a button. Should it?
