Local Time 06:24 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bug in MMBasic - STATIC variables in interrupt routines
Posted: 02:56pm 08 Dec 2020
I've discovered a bug in MMBasic that seems to be common to all versions and have informed Geoff.
If you use interrupt routines with static variables make sure that the static variable names are unique otherwise static variables with the same name in other subroutines may be corrupted.
SimpleSafeName
Posted: 04:46pm 08 Dec 2020
Nice catch, good to know.
And you can do a work-around, then it's a "feature". :)
