Local Time 06:24 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Is there a way to manage Heap size?
RCMAN
Posted: 04:07pm 09 Dec 2020
I'm reading large sprites and getting the error "Not enough heap memory"
I looked up an option for it and didn't find one.
Can I increase it?
RC
Posted: 04:11pm 09 Dec 2020
No
The issue is in the decoding of PNG files which use huge amounts of memory. One workaround is to convert large png to bmp read these into memory and then use sprite read to convert the image into a sprite
The other thing you can do is make sure you load sprites before setting up any array or string variables
Edited 2020-12-10 02:18 by matherp
RCMAN
Posted: 05:37pm 09 Dec 2020
  matherp said  No
I converted to BMP and still getting the error.
     for i = 1 to 59
                 '  load bmp "00"+str$(i)
     if i < 10 then
        load bmp "gfx/000"+str$(i)+".bmp"
'         blit 0,0,0,256,256,256,1
       'print "000"+str$(i)+".bmp"
      sprite read i,0,0,256,256,1
        else
        load bmp "gfx/00"+str$(i)+".bmp"
       'print "00"+str$(i)
     sprite show i,100,100,0
gfx.zip
    end if
Attached the images
RC
Posted: 05:46pm 09 Dec 2020
You are simply trying to load too much data
Assume 8-bit colour mode
256x256 = 64k
*2 (original image  + screen save) = 128k
*59
= 7552K = 7M
Available memory
5M
RCMAN
Posted: 05:48pm 09 Dec 2020
  matherp said  You are simply trying to load too much data
256x256 = 64k
*59
= 7552K = 7M
Available memory
5M
Okay thanks. I'll make them smaller :)
RC
