Local Time 03:49 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Built in editor - pageUp/pageDown
electrotrains
Posted: 01:54pm 18 Dec 2020
Hi all,
(Apologies if I've posted this twice - but I think something went gone wrong with my original attempt to post this suggestion)
Basically, I'd like to suggest an improvement to the way the Page up and down keys work, since I find the current behaviour to be different and less useful than the other IDEs I regularly use.
I think that they should always move the cursor through the file by the number of lines displayed in the editor (48?).
With this way of navigating, it makes it very easy to use the Page up and down keys to check things in the surrounding code as you are typing, then simply page back to return to exactly the same place where you were typing.
Both Visual Studio and Netbeans work this way and I find it really natural and useful.
Note that these IDEs also remember the horizontal position of the cursor and will maintain this position as you page up and down. Even if the cursor ends up on a shorter line, the target position is still maintained - unless you use the cursor keys which seem to reset it.
Hope this is clear enough, and will be given some consideration.
Robin
https://github.com/robinhedwards
epsilon
Posted: 08:44am 19 Dec 2020
XEdit works the way you're suggesting:
https://github.com/epsilon537/xedit_cmm2
I hope you don't mind the shameless self-promotion.
Epsilon CMM2 projects
electrotrains
Posted: 03:52pm 19 Dec 2020
Thanks epsilon - that looks great - I'll give it a try.
Robin
Turbo46
Posted: 02:19am 27 Dec 2020
MMEdit also works that way as does LibreOffice Writer and Notepad. It does seem more intuitive and as you say, you can page up and down and return to the same place in the file. Plus it's more confusing when going from one to another.
Another thing I would like for the File Manager is to have the ability for you to type a letter and have the cursor jump to the first file name beginning with that letter, then to the next and so on.
It would also be nice if a key (^B?) could take you to the first .bas file and then the next and so on. I realize that the status line is getting a bit full
Bill
jirsoft
Posted: 12:45pm 27 Dec 2020
  Turbo46 said  Another thing I would like for the File Manager is to have the ability for you to type a letter and have the cursor jump to the first file name beginning with that letter, then to the next and so on.
Bill
Napoleon Commander is working so...
Jiri
