Local Time 03:49 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Counting Pin
palcal
Posted: 10:59pm 28 Dec 2020
I have a pin set to CIN, how can I set an initial value for the pin. I have tried Pin(15)=number but it doesn't work. I am trying to save the value of the pin and then reinstate it later.
Turbo46
Posted: 11:17pm 28 Dec 2020
I don't think you can set it to a particular value. You can set it to zero by issuing the SETPIN command again though. Can you use a variable as an offset and add the count from the pin to another variable.
Bill
palcal
Posted: 11:25pm 28 Dec 2020
Yes, that is what I was doing but I was changing a few things and thought I would save the Pin value. I'll revert to the old way.  Thanks.
