Local Time 01:19 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Yet another Clock
William Leue
Posted: 09:13pm 25 Jan 2021
I seem to be into clocks today   Here is the second one, a very simple Binary-Coded Decimal (BCD) clock.
The picture shows the displayed time of 15:59:32 (24-hour time). Each column is a single digit of the time, hours for the leftmost 2 columns, minutes for the middle, and seconds for the rightmost 2.
Each column shows the binary equivalent of the decimal digit for that column, with the 1's bit at the bottom (yellow), 2's bit above it (green), 4's bit above that (blue) and the 8's bit at the top (red).
Using constants at the top, you can choose not to display seconds, and also switch between 12-hour and 24-hour time.
Enjoy!
-Bill
BCDClock.zip
William Leue
Posted: 06:57pm 26 Jan 2021
I forgot to mention a little bit of history related to this clock. I first built a physical clock with this output in 1969 using surplus AT&T stepping relays. The mechanism weighed about 25 pounds! Just a couple of years ago, I reimplemented it using an Arduino Uno, which weighs a few ounces. Times change!
-Bill
cletus3x
Posted: 07:14pm 26 Jan 2021
  William Leue said  I forgot to mention a little bit of history related to this clock. I first built a physical clock with this output in 1969 using surplus AT&T stepping relays. The mechanism weighed about 25 pounds! Just a couple of years ago, I reimplemented it using an Arduino Uno, which weighs a few ounces. Times change!
-Bill
Awesome story Bill!  Thanks for sharing.
-George
CMM2 Demos:
Kit Cat Clock
BCD Clock Video
cletus3x
Posted: 08:28pm 26 Jan 2021
Bill,
Ran this one as well.  Nice work!
-George
BCD Clock Video
Edited 2021-01-27 06:29 by cletus3x
CMM2 Demos:
Kit Cat Clock
BCD Clock Video
