Forum Index : Microcontroller and PC projects : Armmite F4: BLIT WRITE seem to interfere with string array
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3879 |
Using the bmp file in the attached zip, this code shows the problem I'm seeing: Dim integer i,j,k,x=10,y=0,lblue=RGB(172,209,255) box 0,0,320,240,,rgb(white),lblue dim string labels(10) for i=0 to 10: labels(i)="Label "+str$(i):next i font 7: cls lblue x=0:y=0:for i=0 to 10: text x,y,labels$(i),,7,,rgb(black),lblue: print str$(i)+": "+labels$(i): y=y+12: next i do while inkey$="": loop geticons do while inkey$="": loop cls lblue:x=0:y=00:for i=1 to 6:blit write i,x,y,50,50:x=x+52:next i do while inkey$="": loop cls lblue x=0:y=0:for i=0 to 10: text x,y,labels$(i),,7,,rgb(black),lblue: print str$(i)+": "+labels$(i): y=y+12: next i do while inkey$="": loop x=100: y=0: for i=0 to 10: text x,y,labels$(i),,7,,rgb(black),lblue: y=y+12: next i blit write 1,80,180,50,50 x=200: y=0: for i=0 to 10: text x,y,labels$(i),,7,,rgb(black),lblue: y=y+12: next i end sub geticons 'local integer i,j,k,x,y Load image "icons.bmp" for i=1 to 9: on error skip: blit close i: next i k=1:x=0 for i=1 to 3 y=0 for j=1 to 3 blit read k,x,y,50,50: y=y+50:k=k+1 next j x=x+50: y=0 next i end sub First I PRINT and TEXT 11 string array elements to the LCD and await a keystroke; then I load the bmp file, extract 9 BLIT buffers and await a keystroke; then I BLIT WRITE 6 of the BLIT buffers and await a keystroke; then I again TEXT and PRINT the same 11 string array elements to the LCE and await a keystroke, but they are garbled. Is there anything evident that I am doing wrong? ARMmite MMBasic Version 5.05.10. icons.zip Edited 2021-02-09 05:17 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Further info: after rebooting, the program works the first time, but not subsequently. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1151 |
It looks like the line for i=1 to 9: on error skip: blit close i: next i causes a few problems. The next read of blit seems to overwrites the variables in the program. See code below where I have put the closing of the BLIT buffers at the end of the main program and removed ON ERROR SKIP. Once the CPU is restarted runs OK from then on. I think relying on ON ERROR SKIP to manage the opening/closing of the BLIT buffers is probably not a good practise. Gerry Dim integer i,j,k,x=10,y=0,lblue=RGB(172,209,255) box 0,0,320,240,,rgb(white),lblue dim string labels(10) for i=0 to 10: labels(i)="Label "+str$(i):next i font 7: cls lblue x=0:y=0:for i=0 to 10: text x,y,labels$(i),,7,,rgb(black),lblue: print str$(i)+": "+labels$(i): y=y+12: next i do while inkey$="": loop geticons do while inkey$="": loop cls lblue:x=0:y=00:for i=1 to 6:blit write i,x,y,50,50:x=x+52:next i do while inkey$="": loop cls lblue x=0:y=0:for i=0 to 10: text x,y,labels$(i),,7,,rgb(black),lblue: print str$(i)+": "+labels$(i): y=y+12: next i do while inkey$="": loop x=100: y=0: for i=0 to 10: text x,y,labels$(i),,7,,rgb(black),lblue: y=y+12: next i blit write 1,80,180,50,50 x=200: y=0: for i=0 to 10: text x,y,labels$(i),,7,,rgb(black),lblue: y=y+12: next i ' Close the buffers here for i=1 to 9 : blit close i: next i end sub geticons 'local integer i,j,k,x,y Load image "icons.bmp" ' Dont use on error to hide the errors 'for i=1 to 9: on error skip: blit close i: next i k=1:x=0 for i=1 to 3 y=0 for j=1 to 3 blit read k,x,y,50,50: y=y+50:k=k+1 next j x=x+50: y=0 next i F4 H7FotSF4xGT |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11873 |
Perfect diagnosis which has allowed me to find the problem instantly. I'll post an ArmmiteF4 firmware update later today |
Excellent. Thank you. I put the BLIT CLOSE i at the beginning because if the program fails, and the BLIT buffers have not been closed, BLIT READ will fail at the next run of the program because unlike on the CMM2, the BLIT buffers appear to persist in some way between program runs. (If that is fixed, it would be great--they'd never have to be closed in my usage thus far.) PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
With the new F4 MMBasic, I no longer need to do BLIT CLOSE for each BLIT buffer before a program is rerun. That's good. But there's a new oddity: after running the program and quitting with Ctrl-C, I get "Error : Not enough memory" when I run FILES. MEMORY reports "26K (24%) Free". Dim integer lblue=RGB(172,209,255),grey=rgb(192,192,192),i,j,k,l,m,n Dim integer EspFlag=0,iconFlag=1,txtFont=1 Dim integer ls%(2000),nNames=9,degrees, x_endpoint, y_endpoint 'Dim cx% = 225, cy% = 100, wid% = 50 Dim cx% = mm.hres*.75-20, cy% = (mm.vres-40)/2+20, wid% = mm.hres/6 Dim ang! = 0.087266463, rad90! = 1.570796327 '90 degrees in radians Dim string a$,b$,c$,d$,item$,Values(10) length 20 Dim string names$(10) length 15 names(0)="description":names(1)="temp":names(2)="pressure":names(3)="humidity" names(4)="speed":names(5)="deg":names(6)="gust":names(7)="country":names(8)="name" Dim string labels$(10) length 25 labels$(0)="Sky": labels$(1)="Temperature": labels$(2)="Atmospheric Pressure" labels$(3)="Humidity": labels$(4)="Wind Speed": labels$(5)="From the" labels$(6)="Gusting to": labels$(7)="City": labels$(8)="," Dim string points$(16) length 3 =("N","NNE","NE","ENE","E","ESE","SE","SSE","S","SSW","SW","WSW","W","WNW","NW","","") points(15)="NNW": points(16)="N" if iconFlag then: geticons: endif box 0,0,mm.hres,40,,rgb(white),grey box 0,40,mm.hres/2,mm.vres-40,2,rgb(white),lblue box mm.hres/2+1,40,mm.hres/2,mm.vres-40,2,rgb(white),lblue text mm.hres/2,5,"Weather: Milton, Nova Scotia",C,1,,rgb(white),grey text mm.hres/2,20,date$+" "+time$,C,1,,rgb(white),grey compass_rose cx%,cy%,wid% if mm.hres=320 then: txtFont=7: endif getWeather x=10:y=45: for i=0 to 6 if i=2 then text x,y,labels$(i)+": ",,txtFont,,rgb(black),lblue:y=y+15: text x,y," "+Values$(i),,txtFont,,rgb(black),lblue:y=y+15: else text x,y,labels$(i)+": "+Values$(i),,txtFont,,rgb(black),lblue):y=y+15: endif next i circle cx%+15,cy%+15,wid%-6,,,lblue,lblue circle cx%+15,cy%+15,wid%/8,,,rgb(red),rgb(red) ' center n=(degrees+270) mod 360 for i=12 to 18 ' lines offset from center (cx%+15) to make arrow x_endpoint=(cx%+15)+(Cos(n*ang!)*(wid%-8)) y_endpoint=(cy%+15)-(Sin(n*ang!)*(wid%-8)) Line (cx%+i),(cy%+i),x_endpoint,y_endpoint,,RGB(RED) ' Line (cx%+i),(cy%+i),(cx%+15)+(Cos(n*ang!)*(wid%-8)),(cy%+15)-(Sin(n*ang!)*(wid%-8)),,RGB(RED) next i text x,200,"Condition:",,txtFont,,rgb(black),lblue if iconFlag then blit write 2,mm.hres/4,180,50,50 else text x+10,212,Values$(0),,txtFont,,rgb(black),lblue endif do:loop sub compass_rose cx%,cy%,wid% Local a% Text cx%+9,cy%+15-(wid%+17),"N",L,1,,RGB(1,1,1),lblue Text cx%+9,cy%+15+(wid%+5),"S",L,1,,RGB(1,1,1),lblue Text cx%+wid%+20,cy%+4,"E",L,1,,RGB(1,1,1),lblue Text cx%-(wid%)+5,cy%+4,"W",L,1,,RGB(1,1,1),lblue if a%<>a% then Text 10,10,"NE",L,7,,RGB(1,1,1),RGB(134,174,230) Image rotate 6,4,30,30,cx%+(wid%-16)*Cos(.785),cy%-(wid%-16)*Cos(.785),45,1 Text 10,10,"SE",L,7,,RGB(1,1,1),RGB(134,174,230) Image rotate 6,4,30,30,cx%+(wid%-16)*Cos(.785),cy%+(wid%-16)*Cos(.785),135,1 Text 10,10,"SW",L,7,,RGB(1,1,1),RGB(134,174,230) Image rotate 6,4,30,30,cx%-(wid%-16)*Cos(.785),cy%+(wid%-16)*Cos(.785),225,1 Text 10,10,"NW",L,7,,RGB(1,1,1),RGB(134,174,230) Image rotate 6,4,29,29,cx%-(wid%-16)*Cos(.785),cy%-(wid%-16)*Cos(.785),315,1 Text 10,10," ",L,7,,RGB(134,174,230),RGB(134,174,230) ' clear text ' tick marks, every 5 degrees (360/5 = 72) endif For a% = 0 To 71 ' note: for angles, East is zero Line (cx%+15)+(Cos(a%*ang!)*(wid%-4)),(cy%+15)-(Sin(a%*ang!)*(wid%-4)),(cx%+15)+(Cos(a%*ang!)*(wid%+1)),(cy%+15)-(Sin(a%*ang!)*(wid%+1)),,RGB(WHITE) Next ' COMPASS perimiter Circle cx%+15,cy%+15,wid% Circle cx%+15,cy%+15,wid%-4 circle cx%+15,cy%+15,wid%/8,,,rgb(red),rgb(red) ' center End Sub Sub getWeather if EspFlag then: else Open "livr.jsn" For input As #1 Do While Not Eof(1) Line Input #1, a$: ' Print a$ LongString append ls%(),a$ Loop Close #1 ' LongString print ls%(): Print For n=0 To nNames-1 item$=names$(n) Values$(n)=pseudo_json$(ls%(),item$) ' Print item$,Values$(n) If item$="temp" Then: Values$(n)=Str$(Val(Values$(n))-273.15)+"C": EndIf If item$="deg" Then degrees=Val(Values$(n)) i=(degrees+11.25)/22.5 Values$(n)=points$(i) ' print item$,degrees,i,Values$(n) EndIf If item$="humidity" Then: Values$(n)=Values$(n)+"%": EndIf If item$="speed" Then: Values$(n)=Values$(n)+"kph": EndIf If item$="pressure" Then: Values$(n)=Values$(n)+" millibars": EndIf If item$="gust" Then: Values$(n)=Values$(n)+"kph": EndIf Next n endif End Sub Function pseudo_json$(ls%(),key$) local integer i,j,k,l,m local string a,b m=1 pseudo_json$="" Do i=LInStr(ls%(),key$,m) ' Print key$,i If i Then a=LGetStr$(ls%(),i-1,1) b=LGetStr$(ls%(),i+Len(key$),1) ' Print "|";a;"|","|";b;"|"; If a=Chr$(34) And b=Chr$(34) Then ' found the key j=LInStr(ls%(),",",i+Len(key$)+2) If j>0 Then k=i+Len(key$)+2 a=LGetStr$(ls%(),k,j-k) ' Print a If Mid$(a,1,1)=Chr$(34) Then ' remove "s a=Mid$(a,2,Len(a)-2) EndIf If Instr(a,"}") Then: a=Mid$(a,1,Len(a)-1): EndIf pseudo_json$=a Exit Do EndIf EndIf m=i+Len(key$) Else Exit Do ' key not found EndIf Loop End Function sub geticons local integer i,j,k,x,y Load image "icons.bmp" for i=1 to 9: on error skip: blit close i: next i k=1:x=0 for i=1 to 3 y=0 for j=1 to 3 blit read k,x,y,50,50: y=y+50:k=k+1 next j x=x+50: y=0 next i end sub This uses the same "icons.bmp" as before. > run > files Error : Not enough memory > memory Flash: 5K ( 3%) Program (157 lines) 139K (97%) Free RAM: 20K (17%) 32 Variables 68K (59%) General 26K (24%) Free > PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
The BLIT buffers are left in place after Ctrl-C and they use memory so you need to close them before using FILES - this uses memory to sort the filenames |
