Local Time 21:17 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 - scientific format
Nimue
Posted: 01:50pm 22 Feb 2021
One of my sanity inducing mindfull-ness type things I do is look for number sequences.  (See https://oeis.org/ if you want maximum geek).
Currently hunting for numbers of the form:
... which are also square numbers. Where the formula represents a k-agon based pyramid (stacking cannon balls problem).
The following code works fine:
Function sum(x)
   k=8  'an octagonal based pyramid
   sum = ((0.5*k-1)*x^2)-((-0.5*k+2)*x)
End Function
Function is_square$(i)
   If Sqr(i) = Int(Sqr(i))  Then
       is_square$="true"
   Else
       is_square$="false"
   End If
End Function
Sub square()
For x = 1 To 10000000
   If is_square$(sum(x)) = "true" Then
       Print x
       Print #1, x
   End If
Next x
End Sub
square()
but once the numbers get large, they are scaled to scientific notation. Thus...
2
32
450
6272
87362
1.2168e+06
This confuses my students, most of which have not seen this notation before.  I naively thought that if I saved the output to file, that this would expand the number.  Nope.
I know I can add format$(x,"%.20g") to force these larger numbers into expanded form -- but that looks even more like weird code to my students.
Q: Is there any way to either scientific notation and just display the full number?  OPTION SCIBASE OFF for example?
Or is there some other CMM2/MMBasic-fu that can make scientific notation disappear?  Would even be happy if this was just enabled when output is directed to a file?
As a second supplementary Q:
Every number is more than an order of magnitude bigger than the previous - this means that beyond the sixth term the rate of discovery grinds to a halt.  In Python (dont hate me) I have a library that I can load that displays a "spinner" and/or progress bar to show that the code hasn't hung / died. Whilst I can simulate this in the CMM2, the act of "Printing" itself slows the code down.
Other than printing a "..." every 1000 iterations or so, any clever ways to show that code is still running?
Nim
Edited 2021-02-22 23:54 by Nimue
Posted: 01:55pm 22 Feb 2021
print str$(x,15,0)
CaptainBoing
with limitations, if you convert the number to integer you get the significant digits:
> dim a%
> a%=1.2168e+06
> ? a%
1216800
> a%=2^63
> ?a%
-9223372036854775808
etc...
does that help?
Edited 2021-02-22 23:57 by CaptainBoing
Nimue
Posted: 01:59pm 22 Feb 2021
  matherp said  print str$(x,15,0)
Perfect -- that is "easier" for them to understand -- does what it says on the tin.
Thank you.
N
Edited 2021-02-22 23:59 by Nimue
Nimue
Posted: 02:00pm 22 Feb 2021
  CaptainBoing said  dim a%
> a%=1.2168e+06
> dim a%
> a%=1.2168e+06
> ? a%
1216800
> a%=2^63
> ?a%
etc...
does that help?
Nice - yes it does ---
Is "integer" math quicker too? As in:
For x% = 1 to 100000
next x%
or is the % ignored in the above?
Nim
Edited 2021-02-23 00:04 by Nimue
NPHighview
Posted: 04:30pm 22 Feb 2021
...and don't hesitate to teach them scientific (and engineering) notation.  They'll use it forever more.
- Steve
Nimue
Posted: 04:37pm 22 Feb 2021
  NPHighview said  and don't hesitate to teach them scientific (and engineering) notation.  They'll use it forever more.
- Steve
Agree -- but most are only 10-12 years old.  Standard form appears in GCSE (for a couple of marks).
They struggle with significant figures as it is ;-)
edit >>> Odd things happening when i use "quote" function in the forum... adding a URL link??
N
Edited 2021-02-23 02:38 by Nimue
CaptainBoing
Posted: 05:01pm 23 Feb 2021
On the bog standard MM (which I use in reasonable amounts) Integer maths is very much faster than floats, but I don't know how much so on those beasts with hardware FPUs. I suspect there is still a healthy gap... perhaps some tests...
timer=0
for n%=1 to 1000000:next
?timer
timer=0
For m!=1 to 1000000:next
?timer
and following on from NP's tip above, engineering notation is a very good thing to teach. check these out
EDIT: just did the tests myself, given that its on a 48MHz PIC32, there isn't much in it between ints and floats... pleasantly surprised:
Int   23892
Float 26683
just three seconds in it, over 1M iterations... I have new found respect for floats on the humble MM. So not "very much" really - a bit faster
p.s. yes, just recently I have noticed rogue URL tags being inserted in quoted posts too
Edited 2021-02-24 03:38 by CaptainBoing
Posted: 05:46pm 23 Feb 2021
  Nimue said  Odd things happening when i use "quote" function in the forum... adding a URL link??
  CaptainBoing said  p.s. yes, just recently I have noticed rogue URL tags being inserted in quoted posts too
I emailed Glenn about this several days ago. He replied and I sent him some examples, so he's aware of it (said he had fixed something else which might have broken it).
Posted: 06:48pm 23 Feb 2021
Oh, Glenn may be getting too many reports - I also emailed.
Posted: 06:51pm 23 Feb 2021
Cap'n's code for F4:
4667
6816
for CMM2:
688.069
722.549
zeitfest
Posted: 11:29pm 23 Feb 2021
now try
timer=0
i% = i% + 1
?timer
timer=0
x! = x! + 1.0
?timer
Edited 2021-02-24 09:31 by zeitfest
TimD
Posted: 12:09am 25 Feb 2021
Not sure how clever it is, but an efficient method may be to use SETTICK to call a subroutine at regular intervals; the subroutine can then display your current value of x.
Best regards,
Tim.
Plasmamac
Posted: 01:35am 25 Feb 2021
maybe use the VBI ?
mode x,x,x,int
Plasma
Nimue
Posted: 12:22pm 25 Feb 2021
  TimD said  Not sure how clever it is, but an efficient method may be to use SETTICK to call a subroutine at regular intervals; the subroutine can then display your current value of x.
Best regards,
Tim.
Nice  - investigating now
N
Nimue
Posted: 12:24pm 25 Feb 2021
  Plasmamac said  maybe use the VBI ?
mode x,x,x,int
OOhh - that's interesting.
Both replies use interrupts -- off to play.
N
zeitfest
Posted: 01:29pm 25 Feb 2021
  zeitfest said  now try
timer=0
i% = i% + 1
?timer
timer=0
x! = x! + 1.0
?timer
What times show on these ? Anyone ?
Nimue
Posted: 01:54pm 25 Feb 2021
timer=0
i% = i% + 1
?timer
timer=0
x! = x! + 1.0
?timer
CMM2:
3568.879
4387.374
N
Posted: 03:17pm 25 Feb 2021
  Nimue said
timer=0
i% = i% + 1
?timer
timer=0
x! = x! + 1.0
?timer
CMM2:
3568.879
4387.374
N
Something wrong there. With the whole series copied into the prompt, and a dummy command after the final ?timer, I get this:
> timer=0
> ?timer
658.13
> timer=0
> ?timer
695.027
> timer=0
> i% = i% + 1
> ?timer
678.432
> timer=0
> x! = x! + 1.0
> ?timer
711.618
With this
timer=0
?timer
timer=0
?timer
timer=0
i% = i% + 1
?timer
timer=0
x! = x! + 1.0
?timer
x! = x! + 1.0
About 20ms added for "i% = i% + 1" and 16ms for "x! = x! + 1.0".
Nimue
Posted: 03:43pm 25 Feb 2021
The "issue" with mine was:
your code....
timer=0
i% = i% + 1
?timer
Inadvertently I figured the i%=i%+1 needed to be inside the for loop.
my code:
timer=0
for n%=1 to 1000000
  i% = i% + 1
next
?timer
