Local Time 21:16 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 - Progress Bar
Nimue
Posted: 02:22pm 25 Feb 2021
As a spin off from https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=13527
Using SETTICK to make a progress bar works remarkably well:
CLS
MODE 1
PAGE WRITE 1
DIM RANGE AS INTEGER
RANGE = 1000000 'DURATION OF LOOP
SETTICK 1000,PBAR(RANGE)
SUB PBAR(RANGE)
  BOX 53,33,(MM-HRES-103)*(X%/RANGE),MM.VRES-556,3,RGB(GREEN),RGB(GREEN)
  BOX 50,30, MM.HRES-100,MM.VRES-550,3
  PAGE COPY 1 TO 2, B
END SUB
'DO SOME RANDOM STUFF
FOR X% = 1 TO RANGE
  A%=X%
NEXT
SETTICK 0,0,1 'STOP TICKER
PBAR(X%) ' FINISH OFF BAR TO 100%
jirsoft
Posted: 04:39pm 25 Feb 2021
You can also use one from my TUI.INC library.
So your code will be:
MODE 1
PAGE WRITE 1
#INCLUDE "TUI.INC"
DIM STRING dialog = TUIwaitingON("Progress bar test") 'open dialog
TUIwaitingProgress(dialog, 0) 'draw progress bar 0%
FOR X% = 1 TO RANGE
 A%=X%
 TUIwaitingProgress(dialog, 100*X%/RANGE) 'update progress bar in %
NEXT
TUIwaitingOFF(dialog) 'close dialog
Edited 2021-02-26 02:39 by jirsoft
Jiri
