Forum Index : Microcontroller and PC projects : Raspberry Pi 4 with MMBasic with 4K resolution?
| bar1010 Senior Member Joined: 10/08/2020 Location: United StatesPosts: 197 |
Does anyone have a Raspberry Pi 4 running MMBasic with 4K resolution? From what I understand Raspberry Pi 4 can support 4K resolution and MMBasic is available for at least one of the Raspberry Pi computers, but am not sure if MMBasic is available specifically on the Raspberry Pi 4 and if MMBasic supports the 4K resolution "mode". |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11871 |
MMbasic on the Raspberry Pi is no longer supported. There are various versions posted on TBS that may or may not work for any particular application but the number of Pi variants and the constantly moving target of the OS with the overhead of Linux makes it impracticable to support. |
No it won't work on the Pi 4 Pi-cromite manual look up HDMI but it only works on the Pi 3 and below but only works with early versions of Stretch if you want to use Buster or Pi OS it won't work |
