Local Time 21:16 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : str2bin not behaving?
johngill
Posted: 03:40pm 04 Mar 2021
Hi all,
I don't know if it's me being a plantpot, but as far as I understand it, this should give me the value 22:
print str2bin(uint8,"00010110",BIG)
I've put eight 0s and 1s in the string, and it's still giving me string length error. Am I doing something wrong or is this a firmware bug?
I'm on 5.07.00b19
thanks!
Posted: 03:52pm 04 Mar 2021
str2bin and bin2str are used for packing the binary representation of a number into a string. The normal use is for writing binary to and from a file or for converting a string containing binary values such as received from some I2C devices into a MMBasic number. For your usage you need to look at functions like VAL and BIN$
johngill
Posted: 03:57pm 04 Mar 2021
ok, thanks, my misunderstanding.
Posted: 03:59pm 04 Mar 2021
Interestingly, on the F4, this causes a lockup, necessitating a reset.
? str2bin(uint8,"0001011000000000")
toml_12953
Posted: 05:38pm 04 Mar 2021
  johngill said  Hi all,
I'm on 5.07.00b19
thanks!
Try PRINT VAL("&B"+"00010110")
