Local Time 19:19 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sensor MM code examples
lew247
Posted: 01:45pm 14 Mar 2021
Following on from the thread about all the program examples for the cmm2 I thought why not have a thread with examples of code for various modules that are or can be used by any of the MM family?
I'm looking for code for the following modules if anyone has any example codes
  Quote  SI7021 Temp & Humidity sensor
VEML7700 Lux Sensor
VEML6075 UV Sensor
BMP388 Pressure & Altitude sensor
AS3935 Lightning Detector sensor
Here's some codes to start off with, hopefully others will keep this going and it doesn't die as it will be handy to many newcomers and possibly older members also
BME280 Temp & Humidity sensor
'* BME280 routine                                     *
'* Thanks to matherp                                  *
option explicit
option default none
'  BME280 routines and test harness
const BME280_ADDRESS                    = &H77
const BME280_REGISTER_T1                = &H88
const BME280_REGISTER_P1                = &H8E
const BME280_REGISTER_H1                = &HA1
const BME280_REGISTER_H2                = &HE1
const BME280_REGISTER_CHIPID            = &HD0
const BME280_REGISTER_CONTROLHUMID      = &HF2
const BME280_REGISTER_CONTROL           = &HF4
const BME280_REGISTER_PRESSUREDATA      = &HF7
const BME280_REGISTER_TEMPDATA          = &HFA
const BME280_REGISTER_HUMIDDATA         = &HFD
dim integer s16=&HFFFFFFFFFFFF0000 , s16b=&H8000
dim integer s12=&HFFFFFFFFFFFFF000 , s12b=&H800
dim integer s8= &HFFFFFFFFFFFFFF00  , s8b=&H80
DIM INTEGER T1,T2,T3     'uint16_t, int16_t, int16_t
DIM INTEGER P1,P2,P3,P4,P5,P6,P7,P8,P9    'uint16_t, 8 x int16_t
DIM INTEGER H1,H2,H3,H4,H5,H6     'uint8_t, int16_t , uint8_t, int16_t, int16_t, int8_t
dim INTEGER t_fine  'used to store accurate temp reading from temp conversion for use in pressure and humidity conversions
'  Test program
bme280_init
do
 print bme280_read_temp()"C" bme280_read_pressure()"mB" bme280_read_humidity()"% Humidity"    'Temp must be run before pressure or humidity
pause 500
print Altitude " "
 pause 3000
loop
end
function  bme280_read_temp() as float
 local integer var1,var2,adc_T
 local adc%(2)
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_TEMPDATA
 i2c read BME280_ADDRESS,0,3,adc%()
 adc_T=((adc%(0)<<16) OR (adc%(1)<<8) or adc%(2))>>4
 var1  = ((((adc_T>>3) - (T1 <<1))) * T2) \ q(11)
 var2  = (((((adc_T>>4) - (T1)) * ((adc_T\ q(4)) - (T1))) \ q(12)) * (T3)) \ q(14)
 t_fine = var1 + var2
 bme280_read_temp = ((t_fine * 5 + 128) \ q(8))/100.0
end function
function  bme280_read_pressure() as float
 local integer var1, var2, adc_P, p
 local adc%(2)
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_PRESSUREDATA
 adc_P=((adc%(0)<<16) OR (adc%(1)<<8) or adc%(2))>>4
 var1 = t_fine - 128000
 var2 = var1 * var1 * P6
 var2 = var2 + ((var1 * P5)<<17)
 var2 = var2 + (P4 << 35)
 var1 = ((var1 * var1 * P3)\ q(8)) +    ((var1 * P2)<<12)
 var1 = ((1<<47)+var1)*P1\ q(33)
 if var1 = 0 THEN
   bme280_read_pressure =  0' avoid exception caused by division by zero
   exit function
 endif
 p = 1048576 - adc_P
 p = (((p<<31) - var2)*3125) \ var1
 var1 = (P9 * (p\ q(13)) * (p\ q(13))) \ q(25)
 var2 = (P8 * p) \ q(19)
 p = ((p + var1 + var2) \ q(8)) + (P7<<4)
 bme280_read_pressure = p/25600.0
end function
function  bme280_read_humidity() as float
 local integer v_x1,adc_H
 local adc%(1)
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_HUMIDDATA
 i2c read BME280_ADDRESS,0,2,adc%()
 adc_H=(adc%(0)<<8) or adc%(1)
 v_x1 = t_fine - 76800
 v_x1=(((((adc_H<<14)-((H4)<<20)-(H5*v_x1))+16384)\ q(15))*(((((((v_x1*H6)\ q(10))*(((v_x1*H3)\ q(11))+32768))\ q(10))+2097152)*H2+8192)\ q(14)))
 v_x1 = (v_x1 - (((((v_x1 \ q(15)) * (v_x1 \ q(15))) \ q(7)) * (H1)) \ q(4)))
 if v_x1< 0 then v_x1 = 0
 if v_x1 > 419430400 then v_x1= 419430400
 bme280_read_humidity = (v_x1\ q(12)) / 1024.0
end function
sub bme280_init
 local i%,cal%(17)
 i2c open 400,1000 '400KHz bus speed
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_CHIPID
 i2c read BME280_ADDRESS,0,1,i%
 if i%<>&H60 then print "Error BME280 not found"
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_T1
 i2c read BME280_ADDRESS,0,6,cal%()
 T1=cal%(0) OR (cal%(1)<< 8)
 T2=cal%(2) OR (cal%(3)<< 8):   if T2 and s16b then T2=T2 OR s16 'sign extend if required
 T3=cal%(4) OR (cal%(5)<< 8):   if T3 and s16b then T3=T3 OR s16
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_P1
 i2c read BME280_ADDRESS,0,18,cal%()
 P1=cal%(0) OR (cal%(1)<<8)
 P2=cal%(2) OR (cal%(3)<<8):   if P2 and s16b then P2=P2 OR s16 'sign extend if required
 P3=cal%(4) OR (cal%(5)<<8):   if P3 and s16b then P3=P3 OR s16
 P4=cal%(6) OR (cal%(7)<<8):   if P4 and s16b then P4=P4 OR s16
 P5=cal%(8) OR (cal%(9)<<8):   if P5 and s16b then P5=P5 OR s16
 P6=cal%(10) OR (cal%(11)<<8):   if P6 and s16b then P6=P6 OR s16
 P7=cal%(12) OR (cal%(13)<<8):   if P7 and s16b then P7=P7 OR s16
 P8=cal%(14) OR (cal%(15)<<8):   if P8 and s16b then P8=P8 OR s16
 P9=cal%(16) OR (cal%(17)<<8):   if P9 and s16b then P9=P9 OR s16
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_H1
 i2c read BME280_ADDRESS,0,1,H1
 i2c write BME280_ADDRESS,1,1,BME280_REGISTER_H2
 i2c read BME280_ADDRESS,0,7,cal%()
 H2=cal%(0) OR (cal%(1)<< 8):   if H2 and s16b then H2=H2 OR s16 'sign extend if required
 H3=cal%(2)
 H6=cal%(6):   if H6 and s8b then H6=H6 OR s8 'sign extend if required
 H4=(cal%(3)<<4) OR (cal%(4) and &H0F): if H4 and s12b then H4=H4 OR s12 'sign extend if required
 H5=(cal%(5)<<4) OR (cal%(4)>>4):  if H5 and s12b then H5=H5 OR s12
 i2c write BME280_ADDRESS,0,2,BME280_REGISTER_CONTROLHUMID,&H05 '16x oversampling humidity
 i2c write BME280_ADDRESS,0,2,BME280_REGISTER_CONTROL,&HB7      '16x oversampling pressure/temp, normal mode
end sub
function q(x as integer) as integer  'returns 2 raised to the power
 q=(1<<x)
End Function
Altitude = 44330*(1-(BME280_read_humidity()/101325)^(1/5.255))
TSL2561 Lux Code
option explicit
option default none
const intpin = 12 'connect to the INT pin on the TLS2561
const TLSaddr=&B0111001  'Floating, GND is &B0101001, VCC is &B1001001
const TLScontrol = &H00
const TLStiming = &H01
const TLSINTERRUPT = &H06
const TLSCRC = &H08
const TLSID = &H0A
const TLSDATA0LOW = &H0C
const TLSDATA0HIGH = &H0D
const TLSDATA1LOW = &H0E
const TLSDATA1HIGH = &H0F
const TLSCMD = &H80
const TLSCLEAR = &H40
const TLSPOWER = &H03
const TLSLOWGAIN = &H00
const TLSHIGHGAIN = &H10
CONST TLSINTEG402 = &H02
dim integer C1datalow,C1datahigh,C0datalow,C0datahigh,useresult=1
dim float CH1,CH0,lux,gain=0.0625
i2c open 400,1000 'device will run at full speed
i2c write TLSaddr,0,2,TLSCMD OR TLScontrol,TLSPOWER ' turn on the device
i2c write TLSaddr,0,2,TLSCMD OR TLStiming,TLSINTEG402 OR TLSLOWGAIN 'set output every 402msec, gain = 1
setpin intpin,intl,TLS2561int,PULLUP
i2c write TLSaddr,0,2,TLSCMD OR TLSCLEAR OR TLSINTERRUPT,&H10 ' enable interrupts every ADC conversion
do
pause 1000
loop
sub TLS2561int
 i2c write TLSaddr,1,1,TLSCMD OR TLSDATA0LOW
 i2c read TLSaddr,0,1,C0datalow
 i2c write TLSaddr,1,1,TLSCMD OR TLSDATA0HIGH
 i2c read TLSaddr,0,1,C0datahigh
 CH0=(C0datahigh*256 + C0datalow)/gain
 i2c write TLSaddr,1,1,TLSCMD OR TLSDATA1LOW
 i2c read TLSaddr,0,1,C1datalow
 i2c write TLSaddr,1,1,TLSCMD OR TLSDATA1HIGH
 i2c read TLSaddr,0,1,C1datahigh
 CH1=(C1datahigh*256 + C1datalow)/gain
 i2c write TLSaddr,0,2,TLSCMD OR TLSCLEAR OR TLScontrol,TLSPOWER 'clear the interrupt
 if CH0*gain < 500 and gain = 0.0625 then 'switch to low light
     i2c write TLSaddr,0,2,TLSCMD OR TLStiming,TLSINTEG402 OR TLSHIGHGAIN 'switch to high gain
     useresult=0
     gain=1.0
     Print "Switching to high gain"
 elseif CH0*gain > 10000 and gain = 1.0 then 'switch to normal light
     i2c write TLSaddr,0,2,TLSCMD OR TLStiming,TLSINTEG402 OR TLSLOWGAIN 'switch to high gain
     useresult=0
     gain=0.0625
     Print "Switching to low gain"
 else
   select case CH1/CH0 'normal processing
     case IS > 0,<=0.5
       lux = 0.0304 * CH0 - 0.062 * CH1 * ((CH1/CH0)^1.4)
     case IS >0.5,<=0.61
       lux = 0.0224 * CH0 - 0.031 * CH1
     case IS >0.61, <=0.8
       lux = 0.0128 * CH0 - 0.0153 * CH1
     case IS >0.8, <=1.3
       lux = 0.00146 * CH0 - 0.00112 * CH1
     case else
       lux = 0
   end select
   if useresult then 'skip the first result after gain change
     print "ADC count visible + IR=",CH0;
     print "  ADC count IR only=",CH1;
     print " converts to ",lux," Lux"
   else
     useresult=1 'enable for next time
   endif
 endif
end sub
Sorry not sure who to give full credit to for that one
SI1145 LUX Sensor
'*** Thanks to Matherp***
option explicit
option default NONE
'/* COMMANDS */
const SI1145_PARAM_QUERY = &H80
const SI1145_PARAM_SET = &HA0
const SI1145_NOP = &H0
const SI1145_RESET = &H01
const SI1145_BUSADDR = &H02
const SI1145_PS_FORCE = &H05
const SI1145_ALS_FORCE = &H06
const SI1145_PSALS_FORCE = &H07
const SI1145_PS_PAUSE = &H09
const SI1145_ALS_PAUSE = &H0A
const SI1145_PSALS_PAUSE = &HB
const SI1145_PS_AUTO = &H0D
const SI1145_ALS_AUTO = &H0E
const SI1145_PSALS_AUTO = &H0F
const SI1145_GET_CAL = &H12
'/* Parameters */
const SI1145_PARAM_I2CADDR = &H00
const SI1145_PARAM_CHLIST = &H01
const SI1145_PARAM_CHLIST_ENUV = &H80
const SI1145_PARAM_CHLIST_ENAUX = &H40
const SI1145_PARAM_CHLIST_ENALSIR = &H20
const SI1145_PARAM_CHLIST_ENALSVIS = &H10
const SI1145_PARAM_CHLIST_ENPS1 = &H01
const SI1145_PARAM_CHLIST_ENPS2 = &H02
const SI1145_PARAM_CHLIST_ENPS3 = &H04
const SI1145_PARAM_PSLED12SEL = &H02
const SI1145_PARAM_PSLED12SEL_PS2NONE = &H00
const SI1145_PARAM_PSLED12SEL_PS2LED1 = &H10
const SI1145_PARAM_PSLED12SEL_PS2LED2 = &H20
const SI1145_PARAM_PSLED12SEL_PS2LED3 = &H40
const SI1145_PARAM_PSLED12SEL_PS1NONE = &H00
const SI1145_PARAM_PSLED12SEL_PS1LED1 = &H01
const SI1145_PARAM_PSLED12SEL_PS1LED2 = &H02
const SI1145_PARAM_PSLED12SEL_PS1LED3 = &H04
const SI1145_PARAM_PSLED3SEL = &H03
const SI1145_PARAM_PSENCODE = &H05
const SI1145_PARAM_ALSENCODE = &H06
const SI1145_PARAM_PS1ADCMUX = &H07
const SI1145_PARAM_PS2ADCMUX = &H08
const SI1145_PARAM_PS3ADCMUX = &H09
const SI1145_PARAM_PSADCOUNTER = &H0A
const SI1145_PARAM_PSADCGAIN = &H0B
const SI1145_PARAM_PSADCMISC = &H0C
const SI1145_PARAM_PSADCMISC_RANGE = &H20
const SI1145_PARAM_PSADCMISC_PSMODE = &H04
const SI1145_PARAM_ALSIRADCMUX = &H0E
const SI1145_PARAM_AUXADCMUX = &H0F
const SI1145_PARAM_ALSVISADCOUNTER = &H10
const SI1145_PARAM_ALSVISADCGAIN = &H11
const SI1145_PARAM_ALSVISADCMISC = &H12
const SI1145_PARAM_ALSVISADCMISC_VRNG = &H20
const SI1145_PARAM_ALSIRADCOUNTER = &H1D
const SI1145_PARAM_ALSIRADCGAIN = &H1E
const SI1145_PARAM_ALSIRADCMISC = &H1F
const SI1145_PARAM_ALSIRADCMISC_RANGE = &H20
const SI1145_PARAM_ADCCOUNTER_511CLK = &H70
const SI1145_PARAM_ADCMUX_SMALLIR = &H00
const SI1145_PARAM_ADCMUX_LARGEIR = &H03
'/* REGISTERS */
const SI1145_REG_PARTID = &H00
const SI1145_REG_REVID = &H01
const SI1145_REG_SEQID = &H02
const SI1145_REG_INTCFG = &H03
const SI1145_REG_INTCFG_INTOE = &H01
const SI1145_REG_INTCFG_INTMODE = &H02
const SI1145_REG_IRQEN = &H04
const SI1145_REG_IRQEN_ALSEVERYSAMPLE = &H01
const SI1145_REG_IRQEN_PS1EVERYSAMPLE = &H04
const SI1145_REG_IRQEN_PS2EVERYSAMPLE = &H08
const SI1145_REG_IRQEN_PS3EVERYSAMPLE = &H10
const SI1145_REG_IRQMODE1 = &H05
const SI1145_REG_IRQMODE2 = &H06
const SI1145_REG_HWKEY = &H07
const SI1145_REG_MEASRATE0 = &H08
const SI1145_REG_MEASRATE1 = &H09
const SI1145_REG_PSRATE = &H0A
const SI1145_REG_PSLED21 = &H0F
const SI1145_REG_PSLED3 = &H10
const SI1145_REG_UCOEFF0 = &H13
const SI1145_REG_UCOEFF1 = &H14
const SI1145_REG_UCOEFF2 = &H15
const SI1145_REG_UCOEFF3 = &H16
const SI1145_REG_PARAMWR = &H17
const SI1145_REG_COMMAND = &H18
const SI1145_REG_RESPONSE = &H20
const SI1145_REG_IRQSTAT = &H21
const SI1145_REG_IRQSTAT_ALS = &H01
const SI1145_REG_ALSVISDATA0 = &H22
const SI1145_REG_ALSVISDATA1 = &H23
const SI1145_REG_ALSIRDATA0 = &H24
const SI1145_REG_ALSIRDATA1 = &H25
const SI1145_REG_PS1DATA0 = &H26
const SI1145_REG_PS1DATA1 = &H27
const SI1145_REG_PS2DATA0 = &H28
const SI1145_REG_PS2DATA1 = &H29
const SI1145_REG_PS3DATA0 = &H2A
const SI1145_REG_PS3DATA1 = &H2B
const SI1145_REG_UVINDEX0 = &H2C
const SI1145_REG_UVINDEX1 = &H2D
const SI1145_REG_PARAMRD = &H2E
const SI1145_REG_CHIPSTAT = &H30
const SI1145_ADDR = &H60
' Main Program
dim float UVindex
if(read8(SI1145_REG_PARTID)<>&H45) then
print "SI1145 not found"
else
reset_SI1145()
start_SI1145()
do
print "Vis: ",readVisible()
Print "IR: ",readIR()
UVindex = readUV()
UVindex = UVindex /100.0
print "UV: ",UVindex
print ""
pause 1000
loop
endif
end
' Subroutines
sub start_SI1145() 'set up the sensor and start it reading
local integer i
' enable UVindex measurement coefficients!
write8(SI1145_REG_UCOEFF0, &H29)
write8(SI1145_REG_UCOEFF1, &H89)
write8(SI1145_REG_UCOEFF2, &H02)
write8(SI1145_REG_UCOEFF3, &H00)
' enable UV sensor
i=writeParam(SI1145_PARAM_CHLIST, SI1145_PARAM_CHLIST_ENUV OR SI1145_PARAM_CHLIST_ENALSIR OR SI1145_PARAM_CHLIST_ENALSVIS OR SI1145_PARAM_CHLIST_ENPS1)
' enable interrupt on every sample
write8(SI1145_REG_INTCFG, SI1145_REG_INTCFG_INTOE)
write8(SI1145_REG_IRQEN, SI1145_REG_IRQEN_ALSEVERYSAMPLE)
'****************************** Prox Sense 1
' program LED current
write8(SI1145_REG_PSLED21, &H03)' 20mA for LED 1 only
i=writeParam(SI1145_PARAM_PS1ADCMUX, SI1145_PARAM_ADCMUX_LARGEIR)
' prox sensor #1 uses LED #1
i=writeParam(SI1145_PARAM_PSLED12SEL, SI1145_PARAM_PSLED12SEL_PS1LED1)
' fastest clocks, clock div 1
i=writeParam(SI1145_PARAM_PSADCGAIN, 0)
' take 511 clocks to measure
i=writeParam(SI1145_PARAM_PSADCOUNTER, SI1145_PARAM_ADCCOUNTER_511CLK)
' in prox mode, high range
i=writeParam(SI1145_PARAM_PSADCMISC, SI1145_PARAM_PSADCMISC_RANGE OR SI1145_PARAM_PSADCMISC_PSMODE)
i=writeParam(SI1145_PARAM_ALSIRADCMUX, SI1145_PARAM_ADCMUX_SMALLIR)
i=writeParam(SI1145_PARAM_ALSIRADCGAIN, 0)
i=writeParam(SI1145_PARAM_ALSIRADCOUNTER, SI1145_PARAM_ADCCOUNTER_511CLK)
' in high range mode
i=writeParam(SI1145_PARAM_ALSIRADCMISC, SI1145_PARAM_ALSIRADCMISC_RANGE)
i=writeParam(SI1145_PARAM_ALSVISADCGAIN, 0)
i=writeParam(SI1145_PARAM_ALSVISADCOUNTER, SI1145_PARAM_ADCCOUNTER_511CLK)
' in high range mode (not normal signal)
i=writeParam(SI1145_PARAM_ALSVISADCMISC, SI1145_PARAM_ALSVISADCMISC_VRNG)
' measurement rate for auto
write8(SI1145_REG_MEASRATE0, &HFF)' 255 * 31.25uS = 8ms
' auto run
write8(SI1145_REG_COMMAND, SI1145_PSALS_AUTO)
end sub
sub reset_SI1145() 'Reset the sensor
write8(SI1145_REG_MEASRATE0, 0)
write8(SI1145_REG_MEASRATE1, 0)
write8(SI1145_REG_IRQEN, 0)
write8(SI1145_REG_IRQMODE1, 0)
write8(SI1145_REG_IRQMODE2, 0)
write8(SI1145_REG_INTCFG, 0)
write8(SI1145_REG_IRQSTAT, &HFF)
write8(SI1145_REG_COMMAND, SI1145_RESET)
pause 10
write8(SI1145_REG_HWKEY, &H17)
pause 10
end sub
' returns the UV index * 100 (divide by 100 to get the index)
FUNCTION readUV() as integer
readUV= read16(&H2C)
end function
' returns visible+IR light levels
FUNCTION readVisible() as integer
readVisible = read16(&H22)
end function
' returns IR light levels
FUNCTION readIR() as integer
readIR = read16(&H24)
end function
' returns "Proximity" - assumes an IR LED is attached to LED
FUNCTION readProx() as integer
readProx = read16(&H26)
end function
function writeParam(p as integer, v as integer) as integer
write8(SI1145_REG_PARAMWR, v)
write8(SI1145_REG_COMMAND, p OR SI1145_PARAM_SET)
writeParam = read8(SI1145_REG_PARAMRD)
end function
FUNCTION readParam(uint8_t p) as integer
write8(SI1145_REG_COMMAND, p OR SI1145_PARAM_QUERY)
readParam = read8(SI1145_REG_PARAMRD)
end function
sub write8(reg as integer, myval as integer)
i2c write SI1145_ADDR,0,2,reg,myval
end sub
function read8(reg as integer) as integer
local integer i
i2c write SI1145_ADDR,1,1,reg
i2c read SI1145_ADDR,0,1,i
read8=i
end function
function read16(reg as integer) as integer
local integer i(1)
i2c read SI1145_ADDR,0,2,i()
read16=i(0) OR (i(1)<<8)
end function
Posted: 03:04pm 14 Mar 2021
This is a good idea, and I'm planning to do this for the 37-sensor and/or 45-sensor kits, as well as other sensors (and things not sensors, like servos), but I had planned to put it on http://fruitoftheshed.com, where it can perhaps be more organized.
Thanks for the code. I plan to hook up a BM280 soon.
CircuitGizmos
Posted: 04:15pm 15 Mar 2021
Would be nice to copy it to 37 Sensors and 37 sensor documentation as a lot of people that find the 37sensors.com site have become fans of MMBasic.
I need to make another grand pass at that site to include more sensors. I have only added a few things since taking over that effort. MMBasic code for new stuff would be great.
Posted: 04:25pm 15 Mar 2021
  Quote  Sorry not sure who to give full credit to for that one
Guess
Nimue
Posted: 08:05pm 15 Mar 2021
  CircuitGizmos said  Would be nice to copy it to 37 Sensors and 37 sensor documentation as a lot of people that find the 37sensors.com site have become fans of MMBasic.
Love 37sensors -- thank you for sharing.
CircuitGizmos
Posted: 08:16pm 15 Mar 2021
Updating it is in my "spare time" that I don't have. If anyone here has contributions I would add. The 37-45 sensors there can be supplemented by many other inexpensive sensors.
