Local Time 15:20 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Checking serialport  programming techniks ...
Plasmamac
Posted: 07:38am 26 Apr 2021
Hi ,
For my knx project i use a Siemens Knx Adapter which sends the Knx Protokoll over serial.
At the moment i open a port read some bytes and compare the bytes with a prerecorded string.
The knx system send random strings over the time .
Now iam not shure if about the best parsing Technik and if i should close and reopen the port after i get a command. Atm i read a byte and put the chr to a string and the port is always open.
Should i close it every command (20 bytes) and reopen the port?
Should i use a watchdog to restart the programm ? Iam interested in you workflow for this kind of app.
Thx
Plasma
