Local Time 12:01 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Define range of array
bar1010
Posted: 11:36pm 12 Jun 2021
Is there a way to define the range of an array such as
dim integer array1(-10 to 10) or dim integer array2(12 to 24)?
If not, could this functionality be added?
LeoNicolas
Posted: 04:01am 13 Jun 2021
Maybe you can use an auxiliary variable as an offset
' For array1(-10 to 10)
dim integer array1(20), a1_offset=10
array1(a1_offset + -10) = 100
array1(a1_offset +  -9) = 101
array1(a1_offset +  10) = 120
' For array2(12 to 24)
dim integer array2(12), a2_offset=-12
array2(a2_offset + 12) = 0
array2(a2_offset + 13) = 1
array2(a2_offset + 24) = 23
Edited 2021-06-13 17:05 by LeoNicolas
