Local Time 12:02 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to upgrade my micromite
Chrisk
Posted: 03:41am 13 Jun 2021
Hi Guys
Can someone point me to a page that tells me how I upgrade my micromite to the latest revision.
I have a USB to serial converter from grogster, the drivers installed on my computer and the Hex file.
The USB interface seems to be working. What next?
Don't want to hassle grogster   again as he has put in too much time already.
Chrisk
Turbo46
Posted: 04:04am 13 Jun 2021
Which micromite do you have? Geoff's site would be a good place to start.
Bill
Chrisk
Posted: 04:28am 13 Jun 2021
I have a micromite plus (64 pin)
I have tried that but didn't see anything that was remotely what I wanted.
Most sites I visited assumed the micromite was operational.
Chris
Chrisk
Posted: 04:29am 13 Jun 2021
Chris
palcal
Posted: 04:38am 13 Jun 2021
I use the PicProg GUI from Grogsters web site Here
I think it will work with the USB to serial converter I have the 1455 USB inerface on my boards.
edit... click on the last download 'PIC32PROG-and-GUI.zip'
Edited 2021-06-13 14:41 by palcal
Turbo46
Posted: 04:49am 13 Jun 2021
Chris, Do you have the version with the 1455 (microbridge) on it? You mention a USB to serial converter so I'm guessing you don't.
You will need a microbridge or a PICkit 3 to program it if not.
Bill
Chrisk
Posted: 06:50am 13 Jun 2021
Hi Guys
Thanks for that. You wouldn't believe how many times I looked at Grogster's site, downloaded the files as you suggested and they were just in my downloads folder.
Yes I have Grogsters 1455 microbridge.
As there was no readme file with the mentioned files I wasn't sure what to do with them.
I will run and see what happens.
Thanks Turbo46 and Palcal
Chrisk
palcal
Posted: 07:38am 13 Jun 2021
Run the PICPROG GUI top left corner should have the USB port then click on SELECT FILE, find the hex file, then click on Flash PIC32 and it's done.
Edit... of course you need the 1455, I don't know what I was thinking.
Edited 2021-06-13 18:52 by palcal
Posted: 11:36am 13 Jun 2021
  Chrisk said  I have a micromite plus (64 pin)
Unless you need the pins on the MM+-64, you might want to look at the PicoMite.
It's still in alpha, and not quite there yet (still lacking an LCD, but for how long?), but it's dead easy to flash (drag and drop a file). PCBs will be coming.
Posted: 12:33am 14 Jun 2021
Refer to the MicroMite Plus manual page 6 for the firmware programming pins and page 9 for the procedure, most of which is the same as in the MM2 manual. Both manuals are included in Geoff's firmware download.
Chrisk
Posted: 01:11am 14 Jun 2021
Thanks Guys
Got it sorted after receiving an email from grogster.
Chrisk
Posted: 02:59am 14 Jun 2021
No bother, Chrisk - anytime.
