Local Time 07:09 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Win10 freezes with 100% disk usage, no disk activity light
Posted: 11:00pm 16 Jul 2021
Task Manager, when I can get it, shows a few tasks with .1MB per second, most with zero. This started, perhaps after a Windows Update, a few weeks ago. It occurs on several PCs, but of course is most annoying on the one I use most:  i7-3520M, 1TB SSD, 12GB Ram (upgrade to 16GB on order).
Lockup occurs from about one to several minutes. Mouse usually moves, but clicking does nothing and Alt-Tab mostly doesn't work. CPU and memory usages are negligible, and network is usually 0%. When it unfreezes, everything is normal for a while. This happens multiple times a day.
I have a lot of programs open, and a lot of tabs in 3 browsers and 5 text editors--but a month ago this was not a problem.
MalwareBytes reports no problems.
Does anyone have any experience of the like, or any idea what the cause may be?
Posted: 11:44pm 16 Jul 2021
Have you seen this?
LINK...
There is also this post on the Microsoft Forums:
LINK...
Posted: 12:29am 17 Jul 2021
I had not seen those--thank you. That looks like the right track, but instead of the storahci.sys driver that they talk about, I have iaStorA.sys.
So more searching needed, but I suspect this is the right path (and now that I see that, it sounds vaguely familiar, but I don't remember the details).
Posted: 03:15pm 17 Jul 2021
To further update, some suggested updating the SSD firmware. I searched and found that there is a "dashboard" for my 1TB Sandisk/WD SSD. I downloaded it and ran its analyzer, and it said that firmware was up-to-date and performance was normal.
So back to trying to find out if iaStorA.sys may be the culprit, and what may be done to fix it.
