Local Time 07:09 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Relay Module with SPI support for Maximite Expansion System
siwypiotr
Posted: 12:42pm 17 Jul 2021
PS Labs has just released Maximite Expansion System Relay Card compatible with all Maximite 2 models.
Relays are operated using SPI interface or by pin outputs. Modes selected by jumpers no wiring required. Available in 5 relay and 8 relay size.
Presentation YT video can be found here: https://youtu.be/7XWMnP6Z7dQ
5 relay model can be purchased here: https://sklep.pslabs.pl/Relay-Card-Expansion-System-p177
8 relay model can be purchased here: https://sklep.pslabs.pl/Relay-Card-Large-Expansion-System-p178
Other Expansion System products can be found here: https://sklep.pslabs.pl/Expansion-System-c97
Github resource and user manual can be found here: https://github.com/pslabs-ps/CMM2-ExpansionCard-Relay
Have fun and be creative!
Rado
Posted: 08:44am 19 Jul 2021
MacGyver likes this.
Rado
Posted: 09:30am 19 Jul 2021
Btw, can MacGyver use the TV remote to set it off? I guess he can, but can he use WiFi to do that as well?
siwypiotr
Posted: 09:39am 19 Jul 2021
  Rado said  Btw, can MacGyver use the TV remote to set it off? I guess he can, but can he use WiFi to do that as well?
You are right, only Your creativity is a limitation how You want to control this relays. On Github there is instruction how to setup the cards:
code example how to control them with IR remote:
https://github.com/pslabs-ps/CMM2-ExpansionCard-Relay/blob/main/code/ir_relay.bas
Now Im making example how to control them via internet, example will be soon added to Github
Edited 2021-07-19 19:40 by siwypiotr
