Forum Index : Microcontroller and PC projects : RASPBERRY PI ZERO BACKPACK 1B info
Quazee137![]() Guru Joined: 07/08/2016 Location: United StatesPosts: 603 |
I used forum search and found nothing. Mather can you point me to any doc's please. I got a few of the PCBs awhile back and have a use for them in a project for kids here at the condo. Of interest is the header on the right side is pinout same as the RPi? I have the U shaped RPi breakout board and need to know if they'll plug straight into each other or if I'll have to use cable and the main header. To use the LCDPANEL is it only for the MMBasic or is there some python code that can drive them? Is there still an MBasic that runs on the RPi ZERO/W Thanks Quazee137 |
You may find something Here I think you are referring to the PICROMITE it was discontinued. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| led-bloon Senior Member Joined: 21/12/2014 Location: AustraliaPosts: 210 |
Q RPi BackPack Updated board Header on RHS (orientation?) is for SSD1963 LCD U-shaped breakout board should be ok - double check before soldering headers to PCB Do not know of any Linux software that drives either type of LCD panel - but google should help Raspbian Stretch Lite (still available from RPi site - just) plus PicroMite MMBasic is the safest option led edit: added PicroMite Edited 2021-08-04 13:44 by led-bloon Miss you George |
Thanks led-bloom thats the one. Next is there a version of the RPi os that MMBasic will run on? even an out dated one as these will not see the internet just a private network. |
| disco4now Guru Joined: 18/12/2014 Location: AustraliaPosts: 1151 |
Lewis has a link to a version of Raspbian and MMBasic that works in this thread. see LEW247s post here This may help. F4 H7FotSF4xGT |
