Local Time 04:14 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ubuntu/linux mint - help needed
Posted: 10:14am 28 Aug 2021
Please could someone try and install libvtk7.1p and let me know if they see it as corrupt.
sudo apt install libvtk7.1p
If it is corrupt what do I do?
thanks
Edited 2021-08-28 20:15 by matherp
Posted: 11:57am 28 Aug 2021
hi peter,
   from the standard mint repositories, "libvtk7.1p" seems to not be available. there is, however, "libvtk7.1" (no "p" at the end) available. i've verified that mint is happy to download and install 7.1, but have not followed through with the installation yet.
it looks like much newer versions are available from here:
https://vtk.org/download/
is 7.1 (not 7.1p) what you are after? if so, i'll try installing it.
rob   :-)
radio_astro
Posted: 01:42am 29 Aug 2021
Peter,
on my Linux Mint libvtk7.1p is already installed ,possibly by default or due to my selection of software . In any case , doesn't look there is anything wrong with it...
regards,
Hans
LeoNicolas
Posted: 04:49am 29 Aug 2021
Hey Matherp
I'm using the Linux Mint Mate 20.2
These are the available libraries:
$ sudo apt install libvtk7
libvtk7.1p      libvtk7-dev     libvtk7-jni
libvtk7.1p-qt   libvtk7-java    libvtk7-qt-dev
No problem to install it here.
Posted: 06:54am 29 Aug 2021
hi peter,
   "libvtk7.1" (no "p") installs fine.
rob   :-)
Posted: 07:45am 29 Aug 2021
Thanks all
I solved it by re-installing mint and then installing the problem application with the dependency on libvtk7.1p before I let mint update. Must be some sort of versioning dependency conflict
Edited 2021-08-29 17:46 by matherp
Posted: 08:32am 29 Aug 2021
do you know what the difference between 7.1 and 7.1p is, if any?
rob   :-)
Posted: 01:20pm 29 Aug 2021
Obligatory humour:
The p version is perforated, supposedly so that you can get it off the roll more easily without it tearing. Unfortunately, as some people using "other" rolls have discovered, the best way to reinforce a joint is to add perforations.
Sorry, but at least it didn't feature four Yorkshiremen. :)
