Local Time 00:53 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Too Much to Ask For ?
hitsware2
Posted: 01:18am 26 Oct 2021
Would the Picomite download work on this ?
Since it's the same processor ?
my site
Tinine
Posted: 03:27am 26 Oct 2021
I made the assumption of Yes and grabbed a similar product
Apparently, it's sitting on my desk.
Might be able to test it in a few hours
Posted: 06:41am 26 Oct 2021
Nice example of paying more and getting less. :)
This is the cheaper version.
MMBasic should run on any RP2040 board. Just watch out for any reserved pins though as they might not remain standard. You'll probably have to sick with the GPn terminology too, as board pin numbers will almost certainly be wrong.
Edited 2021-10-26 16:44 by Mixtel90
Poppy
Posted: 06:48am 26 Oct 2021
  Mixtel90 said  Nice example of paying more and getting less. :)
Not exactly.
Smaller AND one analog input more.
Depending on what someone really wants and needs.
But comparing the price of course it is questionable.
Andre ... such a GURU?
Posted: 08:01am 26 Oct 2021
Well, yeah...
Of course, if you are brave enough to remove Q1 from a Pico and dab a wire on, you too can have that extra analogue port - and keep everything else.
Actually, I like that module. It's a lot more than a simple breakout board (which I thought it was at first glance), more like a less breadboard-friendly version of the Pico and with more flash.
Poppy
Posted: 08:13am 26 Oct 2021
Does it not fit on a breadboard?
There is also another quite similiar board:
https://shop.pimoroni.com/products/tiny-2040
Posted: 08:26am 26 Oct 2021
I meant the one posed by Tinine. It will fit on 0.1" centres, but that would imply padboard or a pcb, not a general purpose breadboard. You couldn't connect to it.
That one looks neat, Poppy. It's still twice the price of a full one though. :) I could see something like that being useful in a drone or something, to keep the weight down. You do get 8MB of flash though, and all four analogue ports too.
Tinine
Posted: 10:06am 26 Oct 2021
I only ordered it because it was cute
I do have a couple of standard Picos though.
Doesn't look like I'll get to my desk today though
hitsware2
Posted: 02:03pm 26 Oct 2021
Doesn't seem to be one with SD socket ?
my site
Poppy
Posted: 03:15pm 26 Oct 2021
That is exactly what I thought, too, just as a matter of weight.
Otherwise I think the Pico is quite small enough for most projects and ... for that tiny price.
I just would like to have more analog inputs and 4 is a good number.
Anyone having some very exact scales being able to tell the Picos weight?
I do just have one for kitchen stuff, not being very exact at all, but I guess the difference in weight would not be such an issue at all, probably the size.
So the tutorial for cutting the Picos tail off is quite interesting.
Posted: 05:48pm 26 Oct 2021
For analogues, a lot depends on the accuracy you want. You could, for example, use a CD4066B quad bilateral switch (and nothing else) to feed 6 inputs into the 3 on a PicoMite, using a single output to select which 3 you want. The accuracy may not be bang on and it may be a little non-linear (it won't be much worse than the straight PicoMite inputs), but it's probably repeatable and therefore predictable. (With a bit of fiddling and using all 4 switches with 2 digital outputs you can actually get 6 inputs into 2 on the PicoMite. :) )
Those switches are great!
Posted: 05:53pm 26 Oct 2021
  hitsware2 said  Doesn't seem to be one with SD socket ?
Look for the SparkFun Thing Plus. :)
hitsware2
Posted: 08:24pm 26 Oct 2021
I'll try to get comfortable with the ' flash save '
my site
Posted: 08:44pm 26 Oct 2021
If you feel like adding a SD card later they are easy to do and work very well. In the meantime you can always use XMODEM to save backups should you need to.
The Flash slots are great, especially now the system boots up with the program you were working on already loaded. :)
scruss
Posted: 11:05pm 26 Oct 2021
If you want even cheaper, and compatible with the pinout of the QtPy (and perhaps the Pimoroni Tiny 2040 too): Seeed XIAO RP2040.
Should even work with Cytron's (large, purple) Maker Pi RP2040  too.
Another one I use is the SparkFun Pro Micro RP2040. It has one of the I2C ports broken out as a Qwiic connector, but otherwise matches the old Arduino Pro Micro form factor.
The Thing+ RP2040 has an SD card slot, but not all Thing+/Feather format boards do. The daft SparkFun Thing Plus SkeleBoard I got on a whim certainly doesn't.
(I'm a SparkFun/Adafruit/Cytron/Arduino dealer, but probably not near where any of you are.)
Posted: 11:45pm 26 Oct 2021
  scruss said  If you want even cheaper, and compatible with the pinout of the QtPy (and perhaps the Pimoroni Tiny 2040 too): Seeed XIAO RP2040.
Now that's a little powerhouse. Pins would certainly appear to be compatible with picomite MMBasic.
  Quote  (I'm a SparkFun/Adafruit/Cytron/Arduino dealer, but probably not near where any of you are.)
Where are you? I'm in Nova Scotia. There are about a half dozen Canadian regulars.
Poppy
Posted: 04:53am 27 Oct 2021
  Mixtel90 said  For analogues, a lot depends on the accuracy you want. You could, for example, use a CD4066B quad bilateral switch (and nothing else) to feed 6 inputs into the 3 on a PicoMite, using a single output to select which 3 you want. The accuracy may not be bang on and it may be a little non-linear (it won't be much worse than the straight PicoMite inputs), but it's probably repeatable and therefore predictable. (With a bit of fiddling and using all 4 switches with 2 digital outputs you can actually get 6 inputs into 2 on the PicoMite. :) )
Thanks for your recommendation, I am just starting to figure out this alternative, I will check out the CD4066B
karlelch
Posted: 07:16am 27 Oct 2021
My two cents: I tried to load the firmware (5.07.00b30) onto the Arduino Nano rp2040 Connect and while MMBasic started and was responsive, the `Memory` command fails and causes a reboot, suggesting that the firmware does not correctly recognize the memory configuration (ie. the additional 16MB of external flash memory?)
Posted: 07:22am 27 Oct 2021
  Quote  the `Memory` command fails and causes a reboot,
nuke the memory before loading MMBasic
Tinine
Posted: 07:51am 27 Oct 2021
  karlelch said  My two cents: I tried to load the firmware (5.07.00b30) onto the Arduino Nano rp2040 Connect and while MMBasic started and was responsive, the `Memory` command fails and causes a reboot, suggesting that the firmware does not correctly recognize the memory configuration (ie. the additional 16MB of external flash memory?)
That's a very interesting module and it is even stocked by RS and Farnell
