Local Time 00:51 17 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [Example Code] Read Temperature Sensor LM75BD (i2c)
Calli
Posted: 01:09pm 29 Oct 2021
The LM75BD is a cheap temperature sensor I had around in my boxes. This is a slightly better version from the LM75 which has a resolution of 0.5K as opposed to the "B" which is 0.125K resolution.
Datasheet: https://www.nxp.com/docs/en/data-sheet/LM75B.pdf
' Read LM75BD(!) this has 0.125 deg. C resolution! LM75 has 0.5 deg.C
' for LM75 just read ONE byte and set a(1)=0 (untestet!)
' Set accordingly to your schematic
SetPin gp8, gp9, I2C
I2C open 100, 100   ' 100kHz, 100ms timeout
addr = &h4D     'Address of your chip, it is &h48 by default!
Dim As Integer a(2) ' holds the data
 I2C write addr, 0, 1, &H00        ' ask for &H00-temperature register
 I2C read  addr, 0, 2, a()         ' read back 2 bytes (11bits used)
' some testvalues from datasheet
'  a(0)=&B01110
'  a(1)=&B101
'  a(0)=&B11001001
'  a(1)=&B001
 temp = (a(0)<<3 Or a(1)>>5)     ' 2 complement 11bit
 If MM.I2C=0 Then                ' ack?
   If (a(0) And &B10000000) Then ' negative value?
     Print "Temp.: "; Str$(-(2048-temp)*0.125,-4,1); " deg. C"
   Else
     Print "Temp.:  ";Str$(temp*0.125,-4,1); " deg. C"
   EndIf
 EndIf
 Pause 1000
I2C CLose    ' hrmp...
Please comment if you see errors or have suggestions for the binary calculations.
Best,
Carsten
Edited 2021-10-29 23:09 by Calli
