Local Time 23:54 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : As Luck Would Have It !
hitsware2
Posted: 07:46pm 03 Nov 2021
I was able to capture a bit of
The Virtual Cowboys practicing
the background track for their
latest hit .....
Featuring their new synth
" The PicoMite "
Edited 2021-11-04 05:47 by hitsware2
my site
Posted: 06:09am 04 Nov 2021
Catchy tune.
Plasmamac
Posted: 09:22am 04 Nov 2021
Like it
Plasma
Posted: 09:26am 04 Nov 2021
Is this the Picomite playing this with the sound command?
What are you using as the low-pass filter? Sounds really clean
hitsware2
Posted: 11:06am 04 Nov 2021
  matherp said  Is this the Picomite playing this with the sound command?
Yes !
10 k Ohm from each channel summed into 2 n F to gnd .
( definately room for tweaking )
For some reason the PicoMite does WAY better than CMM 2 for music ?
for v = 25 to 0 step -1
sound 1,l,s,440,v
pause 10
next v
Gives a nice envelope ...
On the CMM 2 it would work on only select notes
Edited 2021-11-04 21:12 by hitsware2
my site
Posted: 11:28am 04 Nov 2021
  Quote  On the CMM 2 it would work on only select notes
Please explain and post diagnostic code and I'll try and fix. I'll also add the variable type and channel into the next CMM2 beta
Edited 2021-11-04 21:31 by matherp
hitsware2
Posted: 07:23pm 04 Nov 2021
do
frequency = int(rnd*1000)+100
rest = int(rnd*40)+5
print "frequency =", frequency, "    rest =", rest
for beats = 0 to 3
for levels = 25 to 0 step -1
play sound 1,b,s,frequency,levels
pause rest
next levels
next beats
loop
Not nearly the difference I remembered ....
( very noisy on certain frequencies )
This morning CMM2 slightly more noise but usable .
With PicoMite , if ' b ' channels are used the sound
fades in and out somewhat ... O.K. with ' l ' or ' r '
CMM2 O.K. with ' b '
my site
