Forum Index : Microcontroller and PC projects : Blit on LCDPANEL ST7789_135?
| Calli Regular Member Joined: 20/10/2021 Location: GermanyPosts: 74 |
I hoped that it will have the same things as the others ST7789 (which BLIT). But no? Is it a driver thing or hardware? Best, Carsten |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11864 |
H/W - Waveshare don't bring out the MISO pin so I can't read the framebuffer on the ST7789 |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9134 |
It looks like BLIT is only supported on the ST7789_320. It could be that the display can't be read back on the others, that would be a hardware limitation. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Ahhh! Same for the Pimorini Picodisplay. So they don't just leave MISO out for saving a GPIO :) Thanks for clarifying! Carsten |
