Local Time 23:54 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ArmmiteF4 - how to determine if a display is configured
erbp
Posted: 08:51am 06 Nov 2021
Is there a way on the ArmmiteF4 to determine if a display has been configured or not from within a program (using f/w v5.07.00)?
Also is it possible to determine the values of the OPTION DISPLAY settings - # of lines and # of chars?
Thanks,
Phil.
Posted: 09:18am 06 Nov 2021
From the PicoMite v5.07.00 manual:
Try MM.INFO$(LCDPANEL), which should return the display type or a blank string for none.
MM.HRES would give you the horizontal resolution. If you divide that by the MM.FONTWIDTH value for the system font that might give you the characters/line and similarly for the equivalent vertical values MM.VRES and MM.FONTHEIGHT. Note that you'll have to have that font set as the current one.
I'm only guessing that these will work, I've not tested them as I've no display for my F4 yet. It's on the "To Do" list. :)
disco4now
Posted: 11:44am 06 Nov 2021
MM.VRES\MM.FONTHEIGHT  and MM.HRES\MM.FONTWIDTH  will give you the display settings if you have OPTION LCDPANEL CONSOLE set as this is the calculation it uses to determine the number of columns and rows.
If the CONSOLE is not on ie. OPTION LCDPANEL NOCONSOLE then the display is the default
80 * 24 unless you have set it to something else with OPTION DISPLAY lines,chars
The MM.VRES\MM.FONTHEIGHT calculation will still give the same result, however it wont  determine the display setting like it does when OPTION LCDPANEL CONSOLE is in use.
F4 H7FotSF4xGT
Posted: 12:40pm 06 Nov 2021
The important thing is that MM.FONTHEIGHT and MM.FONTWIDTH only apply to the currently selected font. You can't be in a different font in your program and use them to determine the rows & columns on the console.
erbp
Posted: 09:06am 07 Nov 2021
@Mixtel90 and @disco4now,
Thanks guys - I had forgotten about MM.INFO$(LCDPANEL). I also realised after posting that MM.HRES or MM.VRES could also be used as they would return 0 if no display is configured.
Anyway I have since realised that the second question (how to programatically access the DISPLAY option settings) is the more important one, and is key to knowing how many chars per line and lines per "screen" the console is expecting to be able to use.
When OPTION LCDPANEL CONSOLE is in use, the DISPLAY OPTION is locked at the system derived values based on screen size and font selected for the console. Since there is no way to know for sure what font was selected when the option was set, there is no way to programatically calculate the DISPLAY settings that would apply. When the LCD CONSOLE is not in use, the DISPLAY OPTION is unlocked and can be set manually by the user, so again there is no way to determine what the setting is from within a program. It is ONLY accessible to the interpreter. It would be nice if there were a MM.INFO$(DISPLAY) Read Only Variable that would return the setting so that a program could use it.
In the meantime, for my purpose I will just use the 18 lines x 40 characters value as my program is (currently) targetting a F4 with ILI9341 using OPTION LCDPANEL CONSOLE 1
Thanks for your help anyway.
Cheers,
Phil.
Posted: 09:33am 07 Nov 2021
I wonder if there's a couple of system variables that could be PEEKed?
