Local Time 23:02 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : This Feather is for the Birds ......
hitsware2
Posted: 02:38am 09 Nov 2021
Cassowaries that is .......
Doesn't fly ....
After loading MMBasic ,
does not appear as serial
connection .....
RPi 4B , Buster , MiniCom
The setup is O.K. because
Qt Py 2040 works fine .
my site
Posted: 07:54am 09 Nov 2021
If it came with anything pre-loaded you may need to nuke it to clear the flash
Clear_flash.zip
Just load the attached then re-load MMBasic
Posted: 08:03am 09 Nov 2021
All the variations on the Pico will only have been tested with MicroPython and/or ControlPython. Any support libraries for the additions will have been produced only for those. They are designed to be Python platforms.
Your setup is fine for Pico hardware but may not be for any of the variations on it. I'd suggest that you try with Tera Term under Windows 10 if at all possible as this is known to work well with all MMBasic installations.
It's very likely that future versions of the Pico hardware made by Raspberry Pi will remain compatible with the original though, as they have an interest in keeping them so.
hitsware2
Posted: 02:33am 10 Nov 2021
Thank You ! ....
Still on the ground though .
Looking at the literature ,
there is no more pre-loaded
than the Pico ?
( If I'm understanding it ) ?????
my site
hitsware2
Posted: 02:40am 10 Nov 2021
Thank You ....
I choose to only use Windows as a last resort .
I managed to get the QT Py to do what I wanted
of the Feather ( drive a Midi synth ) , so I ' m
good for now .
The Feather does have some appealing ' Wings ' ,
but I ' ll live without ( for now anyways )
my site
