Local Time 20:59 16 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Raspberry Pi Pico Board (Crowdfunding)
Stefan
Posted: 09:05am 09 Dec 2021
Hello, what do you think of it is that is it compatible with mmbasic?
greetings Stefan
PI Pico Board
Posted: 11:20am 09 Dec 2021
There's no direct software support for LoRa modules built into MMBasic, but from a hardware point of view it should be able to get it to work as it only needs a COM port and two or three output pins. You'd have to handle the COM port and those pins in software.
